Author Topic: MAMEWAH 1.5 and Daphne set-up  (Read 1016 times)
Chester
  • Last login:December 23, 2004, 07:51:02 pm
  • Do I look like I know what you think I'm doing?
« on: September 23, 2004, 08:47:25 am »
I love the new MAMEWAH, it's much more elegant than the older version, and the new ini system makes configuration more straightforward.
This said, I can't get Daphne to work! I installed MAMEWAH 1.5 as a separate install, and Daphne still works under v0.97. I copied all the configuration settings from the old set-up, but when I switch to Daphne, I get no games listed. Pulling up the config menu, there is no "refresh list" item. I have list generation mode set to ROM_folder.
Could someone please post their Daphne.ini file so I can make sure I didn't do something goofy?
Chester
Re:MAMEWAH 1.5 and Daphne set-up
« Reply #1 on: September 23, 2004, 10:42:55 am »
You've probably set it up right...
Edit your \ini\daphne.ini file, and set 'current_list                              0' (at the bottom).
Now in Games List Options you should get the option to 'Generate List' :)
Chester
« Reply #2 on: September 23, 2004, 01:48:34 pm »
That did it!
Thanks Minwah!!
Chester
