Author Topic: SlikStik CO2 Owners: Dimension Question...  (Read 1135 times)
Tommy Boy
  • Last login:April 13, 2010, 04:13:56 am
« on: September 22, 2004, 05:11:38 pm »
Does anyone have the dimensions for the standard CO2 layout?  If not everything, how about just the dimension between the inner two joysticks (P1 Right and P2 Left)?  I'm thinking of ordering a CO2 but I want to make some layout adjustments...
Goz
  • KOTA
Re:SlikStik CO2 Owners: Dimension Question...
« Reply #1 on: September 22, 2004, 05:21:27 pm »
Here are the dimensions of the CO2
Top Panel: 45" Wide X 18 1/2" Deep.
Base: 43 1/2" Wide X 14 5/8" Deep.
Base Pitch: 4 3/4" to 3 3/4" downgrade from back to front.
The distance from center of P1 RIght and P2 Left is 20"
I have one unmounted in my workshop, if you need additional dimensions, let me know.
-Goz
Tommy Boy
« Reply #2 on: September 22, 2004, 06:00:25 pm »
Thanks Gozur!  That should do for now.
BTW, have you used it at all?  If so, how do you like the layout and spacing of controls?  Any complaints?
Goz
  • KOTA
« Reply #3 on: September 22, 2004, 10:34:18 pm »
Nope havent used it yet. It's a new blank. Haven't had enough spare time to put in all the controls.
I actually meant to get the Classic and mistakenly ordered the CO2. Not 100% sure I'll end up using it. It's 45" wide wide and the cab I was thinking of using it with is about 12" narrower than that. I'll get arround to putting it on the cab tomorrow perhaps and decide if it is too big.
-Goz
