Author Topic: quick connect terminal blocks  (Read 1764 times)
jpliberato
  • Newbie
  • Last login:September 22, 2004, 08:12:47 am
« on: September 22, 2004, 08:21:22 am »
Hi everybody,
I'm trying to build my first arcade control.  My goal is to build a cabinet, but I'll start with just a control.
I'm a software geek, but I don't have much experience with hardware (I mean, hacking hardware).  Well, at least I know how to use a solder iron.
My question is very simple.  I'd like to know exactly how a quick connect terminal block works.  Let's say I'm trying to hack a keyboard.  I think I'd solder just one wire on each solder point on the keyboard pcb, and solder that wire on the terminal block.  And, after that, I could connect as many wires as I want in the terminal block.  Is that right?  The problem is that I can't go to a store and ask for a terminal block, because I don't know what it is!  I've never heard about it (since I have no eletronics or eletric experience) and I don't know the name of that thing in portuguese (I'm in Brazil).
Hence, if I get a better description of the device, I have a better chance to find it at a local store.
Thanks a lot!
Gameboy.au
  • Last login:January 11, 2005, 05:54:15 am
  • Cabinet completion: 65%
Re:quick connect terminal blocks
« Reply #1 on: September 22, 2004, 08:27:18 am »
Are you refering to bus-rails (bus bars)?
They are made of copper with screws and you join all your (/ground/) wiring to the bus-rail and then have one wire from that going to your common ground for all the buttons.
http://www.stormcopper.com/design/Electrical-Ground-Bar-2x24htm.htm
(Obviously the one you want would be smaler.
The internet, hey... so they have that on computer's now???
whammoed
  • Last login:April 17, 2026, 12:27:07 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #2 on: September 22, 2004, 08:48:15 am »
I like the european style terminal blocks best:
http://www.globalsources.com/gsol/I/Terminal-block-manufacturers/p/2000000003844/3000000157668/8809769675.htm
no need to solder with terminal blocks.  just screw wires into both sides.  I would recommend, however, that you get an ipac or keywhiz instead of hacking a keyboard.  I have hacked more keyboards than i care to remember and both my projects ended up with IPACs inside.
Craig
  • Last login:September 29, 2014, 05:51:56 am
    • Creation on the Web
« Reply #3 on: September 22, 2004, 09:38:14 am »
I agree. I have hacked a keyboard which took me hours of work and ended up dumping it and going for a IPAC2. It is tidier and worth paying money for.
I love the life I lead. I wish I could afford it.
brained
  • Last login:April 10, 2026, 03:46:03 pm
  • Raised by Atari
    • Nux
« Reply #4 on: September 22, 2004, 02:25:37 pm »
Hi everybody,
Thanks a lot!
Look for it in an electronics shop, they'll know what your looking for!! say:
"eu estou procurando um bloco terminal para conectar fios.
mcdo15
  • Last login:February 16, 2008, 01:49:17 pm
  • why can't i make up my mind
« Reply #5 on: September 22, 2004, 03:41:21 pm »
radio shack has these..im using this to build mine now
