Author Topic: Router bit for t-molding  (Read 1699 times)
brianoneill
  • Last login:January 27, 2017, 04:44:59 pm
« on: September 21, 2004, 09:02:45 am »
Hi guys.
I've finally decided to build the my cab after getting all the I-pac, btns and joysticks working :)
I'm gonna put yellow t-molding on the cab but being not very diy inclined i've not much of a clue as to how to do it.
I'm getting the t-molding from ...http://www.t-molding.com/cart/customer/product.php?productid=22&cat=18&page=1.
I've done a search of the forums and best I can figure out, I need these two items...Slot Cutter 3 Wing #301 - 1/16" #301 $12.00 & Slot Cutter Complete Assmbly #7641, 1/16" - 1/2" shank #7641 $16.00 from http://www.mlcswoodworking.com.
Can someone who knows this stuff let me know if this is infact what I need? I've got the router, just wanna make sure this is the right bit I need ? Help would be much appreciated.
Cheers,
Brian.
SirPeale
  • Green Mountain Man
brianoneill
Re:Router bit for t-molding
« Reply #2 on: September 21, 2004, 09:31:26 am »
Thanks. I had seen both posts but still not ure whether I need the 1/4" or 1/2" shanks set !?
Whats the difference, is this the depth of the cut ?
Which do I need ?
MonitorGuru
« Reply #3 on: September 21, 2004, 09:39:50 am »
As always, it depends on the size of your tool ;)
Most routers are 1/4" shanks (the part below the cutting part).
If you have a more powerful router, it MAY have a 1/2" shank.  A larger shank reduces vibration while turning and reduces heat buildup that can cause the bit to slide out (plunge deeper) while being used.
But if you have a 1/2" router it should have included a 1/2 to 1/4" collet converter.
If you go with 1/4" you're probably safe.  1/2" and you might find yourself upgrading your router.
flampoo
  • Last login:March 20, 2014, 11:41:07 am
  • BYObsession
    • flampoo
« Reply #4 on: September 21, 2004, 10:07:40 am »
Tool. Shank. Slide. Heat. Vibration. Plunge. You're kinda' dirty.
brianoneill
« Reply #5 on: September 21, 2004, 10:10:28 am »
Thanks guys. Learn something new everyday :)
Will order the 1/4" set.
