Author Topic: Fusion Resolutions...  (Read 1636 times)
« on: September 21, 2004, 06:30:38 am »
Is anyone running (Kega) Fusion @ 320x240 on an ArcadeVGA??
On my home & work desktop PC's, I get several fullscreen resolutions to choose from, including 320x240.  However, on my cab with AVGA I don't get the 320x240 option.  Anyone know how I can make this resolution available??
I wonder if it is something to do with the mode being listed in Windows as 321x240?
2600
Re:Fusion Resolutions...
« Reply #1 on: September 23, 2004, 02:52:13 pm »
Minwah, it is the ArcadeVGA since it doesn't support 320*240..  I have this problem with NES Emulators.  The emulator I use is configurable and I just type in 321*240, instead of 320*240.
Maybe the author will add this if you ask?
« Reply #2 on: September 24, 2004, 06:16:57 am »
Good point, hadn't thought of that.  Wierd that it allows 320x240 on my desktop tho, which clearly can't handle that mode (just goes to 640x480 as far as I can tell).
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #3 on: September 26, 2004, 06:24:58 am »
VisualBoyAdvance (tested with 1.7.2) have the same problem.
Insane that ArcadeVGA dosen't support this normal resolution.
« Reply #4 on: September 27, 2004, 07:48:39 pm »
It does, kindof.  The AVGA's 321x240 *is* actually 320x240 IIRC - Andy changed it to 321 for some reason...
