Author Topic: mamewah layout vo.97 ????  (Read 3230 times)
daywane
  • GRRRR!
« on: September 18, 2004, 11:08:14 am »
I have been working on this for a few hrs.
I just got mamewha running ;D ( I have tried many times before) (never could untill I found this sight)
http://www.screenshotarchive.com/mwtutorial.htm
I  want to use the pacman layout
I can not find this . (copied from above web page)
;MISC OPTIONS
Layout Name = Nintendoset 1024x768
Keep Image Aspect Ratio = True
Refresh Snapshot Every Time = False
Mouse Pointer = False
Task Switching = False
WINIPAC Filename =
My emulator 1 config file shows
:misc settings
emulator title = mame
artwork #1 image path = c\mame056b\snap
artwork #2 image path =
ect, ect, ( #2 - 10 i have blank)
artwork #1 file name to replace =
display clone info ( in custome list ) = false
: Screen saver settings
nothing about layout.
I am stumped.
« Last Edit: September 18, 2004, 03:00:53 pm by daywane »
daywane
  • GRRRR!
Re:mamewha layout vo.97 ????
« Reply #1 on: September 18, 2004, 12:02:55 pm »
AHHHH CRAP.  >:(
I just found out mamewha will not flip vertical with pivot pro.
well I will still use it for my other cab.
I still would like to change the layout
« Last Edit: September 20, 2004, 08:41:25 am by daywane »
daywane
  • GRRRR!
« Reply #2 on: September 18, 2004, 02:30:15 pm »
I was able to get my lay out by puting the lay out I wantede in the default folder.
maybe not the right way to do it but it worked.
« Reply #3 on: September 20, 2004, 06:32:53 am »
AHHHH CRAP.  >:(
Yes it will.
daywane
  • GRRRR!
Re:mamewah layout vo.97 ????
« Reply #4 on: September 20, 2004, 08:38:14 am »
Ok .... Please dont leave me hanging  ;)
I like the mamewah (Damn I must rember its mamewah not mamewha)
I realy can not get it to flip.
I have found in the menu ( hitting the #2)
something about 1:1 H and I changed it to V
but nothing happend.  ???
 are you saying mamewah will flip or pivot pro will flip it.
I have pivot pro running and windows and everthing else is vertical except mamewah
« Last Edit: September 20, 2004, 08:40:41 am by daywane »
« Reply #5 on: September 20, 2004, 12:00:56 pm »
As long as you have PivotPro running, you should just be able to use a vertical layout.  I think there is one at www.screenshotarchive.com, or make your own with the resolution figures the wrong way around, eg 480x640, 768x1024.  The screen should flip automatically.
daywane
  • GRRRR!
« Reply #6 on: September 20, 2004, 07:36:26 pm »
thanks.
I can not try it now. I have my vertical pc put away now. I will try it in the morning
