Author Topic: Monitor switch  (Read 1738 times)
Ash...Housewares
  • Last login:August 12, 2006, 02:47:09 pm
  • Who wants some?!
Monitor switch
« on: September 13, 2004, 01:46:58 am »
First, I'd like to extend a special thanks to all of you who have graciously helped me with my previous problems.  My monitor is now up and working like a champ.
That having been said, I'm now looking for a way to make a normal microswitch button act as a toggle for my monitor's power.  I've thought about putting in a big Frankenstein-style throw switch, but that'd just be tacky.   ::)
I've thought about putting in a toggle switch in place of the microswitch as well, but I don't know if that's the way most have had to do it.  However, if the toggle switch is the way to go, can I get any recommendations?
Thanks,
-Ash
"Sure, I could have stayed there.  Could have even been king.  But in my own way, I am king.  Hail to the king baby."
breech
  • Last login:November 17, 2006, 09:19:03 am
Re:Monitor switch
« Reply #1 on: September 13, 2004, 08:14:59 am »
microswitches are momentary - like a control panel button, they only stay on or off as long as something is pressing it. the only reason i can think of using one for monitor power is whenever the cab door is closed the screen powers up? anyway, the switch HAS to be rated above the voltage & current you intend on putting through it. (any 250v switch will do) as far as switches go, theres millions of styles to choose from. i have got a red square shapes, illuminated rocker switch on top of the cab. easy to find & looks good. you could go for a 'panic' button (toggle) , - punch it for on again for off, rocker style (like mine) or momentary. farnell components have a huge range of switches.. might be a good start.
P3 800EB, 128@133, 6g, Awe64, ArcadeVGA, J-Pac, Nanao (Sega) Chassis, 26" Mitsubishi in Allied Industries NBA Jam cab...
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
Re:Monitor switch
« Reply #2 on: September 13, 2004, 11:09:34 am »
You could use a microswitch with a relay. Obviously you'd need to find an appropriate relay. It's on my list of to-do's but it's pretty low down as the rocker does the job fine.
fredster
  • It's all good!
Re:Monitor switch
« Reply #3 on: September 13, 2004, 11:21:13 am »
I have seen some people post this before Dave.  Do you have a schematic of how to do this?  I'd like to try it.
The simplest way is a 120 V toggle switch in line on the monitor cord ?
DaveJ-UK
  • Dirty Dawg
    • ChronicGames.NET
Re:Monitor switch
« Reply #4 on: September 15, 2004, 06:31:32 am »
I haven't really looked into it properly. I just had a quick google search and the top 10 results are all broken links!
I expect the relays are called momentary contact relays. Looking at maplin.co.uk, components/relays/6 and 12V 6A Miniature Relays "Double pole double throw changeover relays" look the most appropriate but you'll need one that can handle a higher voltage.
I'm sure rs components will carry the exact part.
