Author Topic: How do I build a metal control panel?  (Read 2051 times)
txcanoeman
  • Last login:June 23, 2018, 12:01:10 am
« on: September 04, 2002, 11:16:52 am »
OK I have 3 computers for my tabletops and most of the controls.  I will need to use a metal control panel but have never done this before, my last two were wood.  Thanks for any advice or helpful information.
What type of metal?  Where do I get it?  How do I cut/drill the 1 and 1/8
lightspeed
  • Last login:July 26, 2016, 07:48:35 pm
Re:How do I build a metal control panel?
« Reply #1 on: September 05, 2002, 09:42:54 pm »
Plain ol' 1/16" sheet metal will work just fine; however you're going to run into several problems...
Holes can be cut relatively easy with bi-metal drill bits; however, these can be rather expensive and do get dull.
Angled cuts as well as any folding and shaping of the panel will be very difficult.  You're only reasonable option, IMHO, is to contact your local machine shop to see if they'll fabricate a piece based on your specifications.  You'll pay quite a bit on this, but the tools you'd need for anything but a rudimentary panel would probably be more expensive....
As for finishing, standard contact paper would work, on which you could decorate.  Happs sells CP laminate, too -  that would also work just fine.
