Author Topic: Monitor is scrambled and shuts off  (Read 2408 times)
Shogun
  • Last login:September 08, 2004, 11:26:27 am
« on: September 09, 2004, 01:42:09 pm »
I'm looking into buying this cab but the seller says the monitor when turned on is all scrambled and then turns off after a few minutes. I am not knowledgeable at all in this area but if it something such as a power supply issue or a simple repair then I may buy the cab and get the monitor fixed. Does anyone have any idea of what may be causing these symptoms?
Shogun
Re:Monitor is scrambled and shuts off
« Reply #1 on: September 10, 2004, 02:04:05 am »
Nobody has had anything even remotely similar happen?
Ken Layton
  • Guru
  • Technician
« Reply #2 on: September 10, 2004, 03:46:23 am »
The monitor in all likelihood needs a capkit.
Shogun
« Reply #3 on: September 10, 2004, 09:57:08 pm »
Further description of the problem:
"It was scrabbled with lines of color and black. after a few seconds it goes to a single white line in the middle then off."
If it does need a cap kit is this a difficult problem to solve?
menace
« Reply #4 on: September 11, 2004, 08:08:53 am »
sounds like a vertical deflection failure--you may have to replace some IC's--not that difficult but does require some skill.
Ken Layton
  • Guru
  • Technician
« Reply #5 on: September 11, 2004, 11:30:21 am »
And the make & model of the monitor is....????
Shogun
« Reply #6 on: September 11, 2004, 08:46:53 pm »
Nanao Duel 8 Series
Model MS8
I believe thats the stock monitor for an egret.
heres a pic from another website:
Shogun
« Reply #7 on: September 11, 2004, 08:48:48 pm »
ebay pic:
Ken Layton
  • Guru
  • Technician
« Reply #8 on: September 12, 2004, 01:32:22 am »
If it's a model MS8-26U then both resistor R433 (2.2k ohm 1/4 watt) and capacitor C433 (10 uf @ 50 volt) are bad.
If it's a model MS8-26A then C431 (33 uf @ 160 volt), C432 (33 uf @ 160 volt), and C433 (10 uf @ 50 volt) are bad.
