Author Topic: Where to buy isolation xformer?  (Read 2011 times)
Trimoor
  • Last login:November 18, 2006, 09:01:46 pm
  • I like shooting out of helicopters.
    • Trimoor
« on: September 04, 2004, 09:37:01 pm »
I need an isolation xformer for my nintendo monitor.
From what I've heard, it needs to step down the voltage to 100v as well as isolate it.
Where would I get one of theese?
I can only find regular 1:1 isolators.
shadowdrak
  • Last login:November 20, 2005, 04:59:54 pm
  • I'm still a llama!
Re:Where to buy isolation xformer?
« Reply #1 on: September 05, 2004, 04:44:47 pm »
I think you should be able to use a japanese power converter(the type people use for traveling).  they are basically just a transformer in a case. Radioshack probably sells em but i dunno.  Also, dunno what your wattage, amperage requirements are so be careful you don't get one that will burn up as soon as you put a load on it
SirPeale
  • Green Mountain Man
« Reply #2 on: September 07, 2004, 12:24:40 pm »
You need a 1.1:1 ISO transformer.  Ask on RGVAC for one, someone can likely hook you up.
Trimoor
    • Trimoor
« Reply #3 on: September 07, 2004, 04:12:49 pm »
I tried searching, but I can't find "RGVAC".
Could you give me a link?
Raven..
  • Last login:June 29, 2021, 12:51:50 am
« Reply #4 on: September 08, 2004, 01:11:57 am »
You can buy one from tonadoterrys.com  He stocks them adn sells on eBay all the time.  I picked one up from him over the weekend.  He's local to me and is pretty good to deal with.
JJS
  • Last login:January 16, 2007, 04:21:19 pm
« Reply #5 on: September 10, 2004, 01:59:54 pm »
Try http://www.belfuse.com/SignalTransformer/TechLibPage.asp?pRecno=11
You need a DP-241-8-120.  There are 3 terminals on the top, and two on the bottom.  Your 120V will go on either end of the top inputs (leave the center tap unused), then the bottom 2 terminals go to your monitor.  It will give toy 105V.
Trimoor
    • Trimoor
« Reply #6 on: September 10, 2004, 04:35:14 pm »
I bought a 1.1:1 transformer from a store, but it turns out it's an auto transformer.
This means it will not isolate at all.
Can I use this along with a regular 1:1 iso?
Or should I just get a 1.1:1 iso?
Shipping is so expensive...
SirPeale
« Reply #7 on: September 11, 2004, 11:50:02 am »
If you use a regular 1:1 you'll blow your monitor!  Would you like to pump an additional 20 volts thru an application designed to run less?
RGVAC is rec.games.video.arcade.collecting.  You can access it thru http://groups.google.com, or with a newsgroup reader such as XNews.
shadowdrak
« Reply #8 on: September 11, 2004, 01:26:06 pm »
If you are talking about pluging your 1.1:1 automotive tranformer into a 1:1 isolation transformer, then to your monitor, yes that will work.  An isolation transformer is basically the same as a regular power converter type transformer.  The difference is, most isolation tranformers are 1:1, and they usually have some sort of shielding between their coils.  Technically though, all transformers isolate the power.  connect the output terminals of one tranformer to the inputs of the other and you will serve your goals.
