Author Topic: Maruee lighting  (Read 2305 times)
Trimoor
  • Last login:November 18, 2006, 09:01:46 pm
  • I like shooting out of helicopters.
    • Trimoor
Maruee lighting
« on: September 04, 2004, 06:01:28 pm »
My cab is 17" wide, so fluorescent bulbs are nearly out of the question.
I was thinking of using CCFL bulbs to light the marquee.
They are 12" long, come in nearly every color, and are very cheap.
My question is, should I get white, colored, or UV?
UV would be great, but are there any printers that use UV ink?
Would kinkos do this?
I should probably design a marquee first.....
Link to cheap CCFL:
http://www.svc.com/ccfltubes.html
I've bought from them before and they are great.
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:October 08, 2024, 04:40:31 am
  • I am t3h GAY!!!
Re:Maruee lighting
« Reply #1 on: September 04, 2004, 10:09:48 pm »
Call me crazy, but...
Why would fluorescent not be an option?
« Last Edit: September 04, 2004, 10:10:10 pm by versapak »
DougHillman
  • Last login:September 13, 2004, 07:39:18 pm
Re:Maruee lighting
« Reply #2 on: September 04, 2004, 10:13:38 pm »
Any hardware store has flourescents in a range of sizes.  The local Ace carries 12"ers that you wire direct for like $10.00.  That'd work fine in your 17" cabinet.  Is your cabinet really 17" or is that a typo?  Regardless, you shouldn't have any problem finding a flourescent that'll fit fine at any decent hardware store.
If you can't be a good example at least try to be a horrible reminder.
Trimoor
    • Trimoor
Re:Maruee lighting
« Reply #3 on: September 04, 2004, 10:43:07 pm »
yes, it's really 17".
It's an assault cab.
I looked at menards, but i really should check a decent hardware store.
The CCFL bulbs are only about $7 shipped, and they don't flicker, so I'm still leaning towards them.
Picture of cab:
darktemp
  • Last login:July 20, 2006, 11:18:39 pm
  • Rumbler
Re:Maruee lighting
« Reply #4 on: September 05, 2004, 02:33:57 am »
That is a sweet cab.  I actually bought those exact kits from svc (one of the dual kits with 2 12" tubes).  I went for the white, unfortunately unless you can hold off a while for an opinion I'm not going to be much help because I haven't install them yet.
sean69
  • Last login:September 20, 2004, 05:33:47 pm
  • kill all humans...
    • Nexus
Re:Maruee lighting
« Reply #5 on: September 05, 2004, 01:20:39 pm »
I just bought 2 12" flourescent strips yesterday, one went in my cab and the other went under my kitchen cabinet, problem is the one in the kitchen got insanely hot!! I have not checked the one in the cabinet just yet.
I would suggest you check the operating temperature befor enclosing it.
Link to cheap CCFL:
