Author Topic: Monitor Shelf Brackets  (Read 1063 times)
dmish82
  • Last login:September 09, 2005, 10:31:40 am
  • "What is this? A center for ANTS?!?!?!"
« on: September 04, 2004, 02:35:31 am »
hey guys,
i was wondering what size L-Brackets would be good to use for the monitor shelf. I know 2 1/2" ones work well but what width should they be? I have 5/8" thick ones and was wondering if that should do the trick.
Thanks,
Dave
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
Re:Monitor Shelf Brackets
« Reply #1 on: September 04, 2004, 08:59:33 am »
A single #10 nail has a shear strength rating of 80 pounds.
4 5/8" brackets ought to be able to hold up several hundred pounds provided they are properly installed.
As long as your cabinet cannot flex outward, your 5/8" brackets ought to be excellent. If you have 2 screws on each bracket, then you have 8 screws. If your monitor weighs 80 pounds, then you only have 10 pounds on each screw.
Bob
