Author Topic: Touchscreen Jukebox software  (Read 9755 times)
greg0102
  • Newbie
  • Last login:September 03, 2004, 04:19:57 pm
« on: September 03, 2004, 09:54:21 am »
I am trying to put together a touch screen jukebox. I'm leaning toward winamp or virtuosa. I really like the visualations you can put on screen. My question is can I set these up so that if there is no activity for like 2 minutes the visualation would pop up full screen like a screen saver and when you touched the screen it would go away untill no activity again? If not is there any screen saver that is similar? (I havent found any)
mflint
  • Last login:March 01, 2014, 08:47:03 am
  • Shocking
Re: Touchscreen Jukebox software
« Reply #1 on: February 05, 2005, 10:37:43 am »
I'll tell you that (The PCJukebox) Sounds like the perfect
program for you to run if you want a good reliable touch
screen set up. I have found that version 6.02 is better than the 7.0 version. this can be found at :
http//www.thepcjukebox.com
best of luck
str1der
  • Last login:March 04, 2021, 04:35:31 pm
  • Live it!
« Reply #2 on: February 16, 2005, 04:08:20 pm »
Definetly take a look at Nordbeat Jukebox. This program has everything a touchscreen setup could want. I used to use Partytime but switched to this. They have great support also.
http://www.nordbeat.com/
