Author Topic: Problem with Happ Super Joystick  (Read 1589 times)
dexterclaire
  • Last login:September 01, 2004, 04:18:49 pm
  • the arcade version is always better.
    • Inner Peace Security
« on: September 01, 2004, 06:16:11 am »
Hi!
I totally rewired the control panel of my three-year-old mame cab yesterday, and everything worked fine until tonight.  When I click the joystick 'right', the corresponding microswitch registers two keystrokes.  It registers one when the microswitch is pressed, and one when the switch is released.  This seems to totally confuse mame, so I'm thinking i need to replace the switch.  Has this happened to anyone else?  Up, left, and down all register just one keystroke.
Grauwulf
  • Last login:July 27, 2009, 03:42:44 pm
  • Button Masher
Re:Problem with Happ Super Joystick
« Reply #1 on: September 01, 2004, 06:23:49 am »
Sounds like a bad microswitch. Just change it out and your problem should go away.
www.wolfelectronics.ca
Cap Kits for Canadians!
Bill Mote
  • Last login:May 29, 2010, 11:04:28 pm
  • Focus on making things better not bigger.
    • Things That Make Me Mad and How To Fix Them
« Reply #2 on: September 01, 2004, 07:30:15 am »
1st rule of data-comm: check the cable!  Sounds like you wired to the NO and NC instead of the NO and GRND!  Thoughts?
dot
Bill Mote
« Reply #3 on: September 01, 2004, 02:13:20 pm »
Well?!  Did you fix it?!
dot
dexterclaire
« Reply #4 on: September 01, 2004, 04:23:49 pm »
I swapped out one of the microswitches from the Player 2 stick into the one in question on the Player 1 stick, and it works fine, so yeah it's just a bad switch.  I emailed happ about it and they're sending me a couple of replacements free of charge.  Nice folks they are!
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« Reply #5 on: September 01, 2004, 04:31:44 pm »
I had a similiar issue with one of my micro switches, it would push in and then stick.   It was starting to get frustrating when I traced all my connections and couldn't find the problem.   Haven't had any more problems since putting the new switch in.
I wonder how many people have had issue's with bad micro switches?
