Author Topic: 4 Joystick Control Panel Dimensions  (Read 837 times)
dmish82
  • Last login:September 09, 2005, 10:31:40 am
  • "What is this? A center for ANTS?!?!?!"
« on: August 31, 2004, 03:16:07 pm »
Hi,
I'm following the Project Arcade Book building my first cabinet and everything is running smoothly so far. I have all of the wood cut out so far and I've started assembly.  My question is that the book's dimensions of the control panel are to accomodate 2 players. I plan on using 4 joysticks (Players 1 & 2 will have 6 buttons, Players 3 & 4 will have 4 buttons). I won't be adding a trackball but may down the road. Can anyone tell me some dimensions that would be good for a 4 player control panel but not too bulky either? Also, does anyone have any links to a good 4 player control panel layout?
Thanks,
Dave
mcdo15
  • Last login:February 16, 2008, 01:49:17 pm
  • why can't i make up my mind
Re:4 Joystick Control Panel Dimensions
« Reply #1 on: August 31, 2004, 03:38:41 pm »
well...with mdf, the width is 48 inchs wide, just make cuts say 18 inchs or do...you can will be fine with 4 player now and future still add track ball.
this is actually the size of mine and i was able to fit a 4 way joystick and a spinner on ther
good luck
