Author Topic: Golden tee  (Read 1180 times)
vivagolf
  • Last login:April 02, 2005, 10:41:00 am
  • I'm a Novice
Golden tee
« on: August 31, 2004, 01:24:59 pm »
I am new to this, so bear with me.
I am trying to convert a GT 2K to a  GT2002. I have all the necessary parts.
It states that I have to run 2 new wires, one for backspin and one for flyby and run them from pos 20 and 21 to the corresponding button. I see no problem in that.
What I don't understand is, all the buttons have 2 wires to them. What other wire do I use and where does it come from.
Thanks,
Larry
johnnysmitch
  • Last login:November 16, 2006, 02:22:05 pm
  • I want you to MAME me as hard as you can
Re:Golden tee
« Reply #1 on: August 31, 2004, 01:33:47 pm »
the other wire on each button should just be a ground wire - you should be able to just run them to the ground wire on any other button
vivagolf
  • I'm a Novice
Re:Golden tee
« Reply #2 on: August 31, 2004, 01:39:00 pm »
Thank you,
I kinda figured that was it but on the other 3 buttons the wires were of different colors.
