Author Topic: HELP!!! MAMEWAH issue. Having to use mouse...  (Read 1163 times)
AGGIEZ
  • Last login:January 30, 2017, 05:59:50 pm
« on: August 31, 2004, 10:21:26 am »
This is a new issue for me. Not really sure how it happened. I have MAMEWAH, and only MAMEWAH, in my Startup folder so that it starts immediately when Windows opens.
Not sure what I did, but now, the taskbar at the bottom is now showing up in FRONT of the MAMEWAH skin. When MAMEWAH opens, it isn't active, meaning I have to use my mouse and click on my MAMEWAH skin before I can start scrolling through the games.
Anyone know how I can fix this? I really don't want to have to use my mouse every time I start up my cabinet.
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
Re:HELP!!! MAMEWAH issue. Having to use mouse...
« Reply #1 on: August 31, 2004, 12:48:52 pm »
I have solved various odd errors and glitches in the past by deleting MAMEWAH.CFG in the FILES folder. Most of the time you will only have to set a couple of options again, such as your skin and music dir
simplygriff
  • Last login:January 10, 2008, 10:05:05 am
    • simplygriff.com
« Reply #2 on: August 31, 2004, 04:37:18 pm »
If you're using XP you may have the taskbar set to always be on top.  You can set this by right clicking the bar and modifying the properties.
-G
www.simplygriff.com
art : videogames : transformers : life
Live, but Under Heavy Construction
