Author Topic: Help w/ jPac wiring - speaker inq.  (Read 1429 times)
General Zod
  • Last login:June 23, 2005, 03:58:28 pm
  • Banned
« on: August 29, 2004, 06:20:00 pm »
Greetings,
I just have a quick question regarding the jPac and wiring the speaker connections from a jamma harness. I've tried searching the faq, but no avail.. ???
I've decided to use the speaker hack, and wire the existing cab speaker to a torn apart set of creative's ... my question is this .... Since I'm using the speaker hack to generate sound, will I still need to use the speaker + & -  wires form the jamma harness and connect to the jPac?   ( i hope that makes sense )  ;)
Thanks in advance for your help.
Michael
SirPeale
  • Green Mountain Man
Re:Help w/ jPac wiring - speaker inq.
« Reply #1 on: August 29, 2004, 07:19:41 pm »
Since the existing speakers should already be attached to the JAMMA harness, wire the output of the speaker amp to the speaker input on the J-PAC.
General Zod
  • Banned
« Reply #2 on: August 29, 2004, 10:11:28 pm »
That sounds like a plan ... I appreciate your help Peale.
Thank you!  :D
Mike
microwrx
  • Last login:July 06, 2008, 09:22:02 am
« Reply #3 on: August 30, 2004, 04:08:22 am »
Remember it's only a mono connection.  If you want stereo you will have to bypass the J-PAC and JAMMA and go straight from the amp to the speakers.
