Author Topic: Playstation to usb problems  (Read 2221 times)
Squirrely
  • Last login:August 24, 2004, 08:55:35 am
« on: August 27, 2004, 01:49:09 am »
I have a playstation to usb adapter that seems to do something weird.  It registers up, down, left, and right but not when you press up and down at the same time or left and right at the same time.  I have it hacked and going to a dance pad so I need to be able to register both directions simultaniusly.  Has anyone else had this problem with adapters and if so, how can it be fixed?  Can I expect the same anoyance when going from Playstation to xbox?
TalkingOctopus
    • My Arcade
Re:Playstation to usb problems
« Reply #1 on: August 27, 2004, 02:08:38 am »
I think that is a common problem with some types of the USB adapters.  However, this USB one will work w/ DDR:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=41059&item=8127127359
Antiriad2097
  • Last login:June 08, 2006, 11:34:53 am
  • New to arcade builds, an old hand at arcades
« Reply #2 on: August 27, 2004, 02:37:11 am »
It is indeed a common problem and it is device dependent. Easiest way to fix it is to buy a new adapter I'm afraid - usually the ones that work with dance mats specifically say so.
Bought mine from play.com for
Anti-R/ad
abrannan
  • Last login:July 25, 2012, 11:32:14 am
  • Building a cabinet in perpetuity since 2002
« Reply #3 on: August 27, 2004, 09:36:32 am »
Some PS->USB adapters have a dance mode that maps the d-pad axes to button presses, allowing simultaneous up/down or left/right presses.  You have to hold start+select+up on the controller for three seconds to enable this mode.
stepmania.com has a list of working and non-working ps->usb adapters.
If no one feeds the trolls, we're just going to keep eating your goats.
