September 23, 2026, 08:19:36 am
Hmm what is a magic eye
My boss used to have a program to do that... He wanted to make buisness cards.. But it ended up that you need the image to be a certain size to really work.
I used to play around with these (there are all sorts of ways to make these, you can actually make them using text, but it's been to long to remember all those little tricks). There is a program I used to use to make them, it's a pretty basic paint program where each color is a different depth. If you play around with it, you can get some good results. The program is called RDSdraw, you can get it from http://home.rotfl.org/prg/rdsdraw/rdsdraw.html. Hope that helps.
