Author Topic: Help with powering up cab.  (Read 1083 times)
fastredpacman
  • Last login:February 19, 2018, 02:12:36 am
  • What?
« on: August 26, 2004, 02:44:50 pm »
I just purchased this cabinet and it doesn
paigeoliver
  • Awesome face!
Re:Help with powering up cab.
« Reply #1 on: August 26, 2004, 03:01:56 pm »
Is the back door on the machine?
Are you getting AC power to the power supply?
To the monitor?
Does the monitor neck light up?
Do you hear ANYTHING out of the speakers (you can usually hear some sort of hum or something if the audio amp is powered).
Do you own a multimeter?
Does that machine have the kind of monitor that has no frame, if so, then that is a nice monitor, you might want to see if the monitor works before giving it away.
fastredpacman
  • What?
« Reply #2 on: August 26, 2004, 05:27:39 pm »
Yes the backdoor is on the machine. I don't know how to check if Ac power is going to the power supply or the monitor. Nothing lights up, not the monitor, lights , anything. I dont hear anything from the speakers. I don't own a multimeter. I don't think the monitor has a frame. I really appreciate any help you could give me.
« Last Edit: August 26, 2004, 05:29:11 pm by fastredpacman »
paigeoliver
  • Awesome face!
« Reply #3 on: August 26, 2004, 05:56:46 pm »
Ok, definitely an ATW cabinet, I recognize some of the internal components too.
Ok, your first step is to buy a multimeter from radio shack, just get the cheapest one.
Here is an article that will teach you how to use the multimeter.
http://slot-tech-ftp.serveftp.com:8080/general%20electronics/dmm/dmm.htm
