Author Topic: DirectX Programming for ArcadeVGA card  (Read 2123 times)
chowny
  • Last login:August 17, 2006, 04:08:01 pm
  • ArcadEPIC author and World's Greatest Lover
    • ArcadEPIC homepage
« on: August 26, 2004, 04:42:20 am »
Hello all
I am well into the development of YAMFE (Yet another Mame front end). I want to make one that is sort of tailored towards arcade monitors, but that runs under windows.
I have the program working quite well on my dev machine, but I can't seem to set the directX modes on my cabinet (using the ArcadeVGA card and an arcade monitor)
The directX modes work in windowed mode but if I set the fullscreen flag, I get an error saying that the device has failed and that I need to reboot before DirectX will work properly again.
Its not an issue of using a resolution that ArcadeVGA doesn't support, as I have enumerated all the supported video modes and am choosing one of them.
Any suggestions where I might be going wrong?
Regards
 Stephen
 sdchown@yahoo.com
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
Re:DirectX Programming for ArcadeVGA card
« Reply #1 on: August 26, 2004, 09:12:13 am »
Are the dev and test/cab machines running different OS's? This has caused me problems in the past (95/98
* DaveJ-UK Vs. 2000/XP), although I have never played with DirectX.
Do you have the latest version of DX (9.0b I think it is) installed on both machines?
« Last Edit: August 26, 2004, 09:12:45 am by DaveJ-UK »
chowny
« Reply #2 on: August 26, 2004, 09:27:01 am »
Yes. Same OS (WindowsXP), same version of DirectX (9 on both). Different Video cards of course.
My DEV machine is a laptop with a Nvidia chipset card. I am starting to suspect its a refresh rate issue. But I can't be sure. I think I'm going to have to install my development environment (in this case Delphi) on my cabinet so that I can trace the code.
Working on the cab like this is gonna be a nightmare though, so its a last resort.
DaveJ-UK
  • Dirty Dawg
    • ChronicGames.NET
« Reply #3 on: August 26, 2004, 11:18:24 am »
I think you are probably right.
Have you tried any other DirectX apps?
chowny
« Reply #4 on: August 26, 2004, 03:15:55 pm »
Well, MAME runs fine. And that uses DirectX (I think). Maybe one of the Mame Dev's would be able to help me.
Who knows.
I am at a loss. Google on the error I get "Microsoft windows detected and recovered from a...blah blah" seems to suggest that its a problem with ATI Radeon chipset.
God help me.   :(
Later
 Stephen
AlanS17
    • AlanS17
« Reply #5 on: August 26, 2004, 04:27:31 pm »
Maybe you need a more current version of the ArcadeVGA drivers (just throwing that out there).
chowny
« Reply #6 on: August 27, 2004, 02:00:40 am »
SOLVED! It seems that the Radeon 9X00 chipsets don't like some Intel Motherboards.
Disabling some of the Hardware accelleration seems to have done the trick.
Thanks to all
 Stephen
