Author Topic: Resolution Problem ***********  (Read 2413 times)
koolmoecraig
    • My Intervention
« on: August 24, 2004, 03:35:07 pm »
Hello all,
Ok, so I got my Q*Bery monitor all hooked up and everything is fine EXCEPT.
My monitor is Vertical 256x240 resolution, so I only want to play games that can display on it without stretching(pac man,Dkong etc).
I am using the Ultrastyle frontend. The problem is the Ultrastyle front end looks like complete crap at 256x240. But if I set it at any other resolution, like 800x600, It looks great but then I have to adjust the horizontal hold whenever I start a game.
What the heck am I doing wrong here? If I set the resolutions to 800x600 all around, everything looks good, but not great.
Any ideas?
P.S. I still need a Q*Bert control panel if anyone has one laying around.
Re:Resolution Problem ***********
« Reply #1 on: August 24, 2004, 04:09:05 pm »
Try my 'ArcadeVGA MAME Res. Tool' (from my downloads page) - that should sort out any problems while playing games...
As for the FE, why does it look like crap at 256x240?
koolmoecraig
    • My Intervention
« Reply #2 on: August 24, 2004, 04:31:39 pm »
Ultrastyle uses the marquees on the scroll wheel. at 256x240 everything on the screen except for the text is way blurry.
I have used your res tool and everything is fine on that end. Basically I need to find the highest possible resolution that Ultrastyle will work at while keeping the games at 256x240.
Is 720x480 the highest possible?
Thanks again!
« Reply #3 on: August 24, 2004, 05:12:45 pm »
Probably...what does it look like at 640x480 tho?
