Author Topic: Messed monitor. Any help?  (Read 1406 times)
Ash...Housewares
  • Last login:August 12, 2006, 02:47:09 pm
  • Who wants some?!
« on: August 24, 2004, 02:52:12 pm »
I'm so embarrassed :-[.  I tried the monitor hack, and I think I fried my monitor.
What I did:
I connected the red, green, blue, and ground pins to 1,2,3, and 5 respectively.   Then I connected the negatve horizontal sync to pin to pin 13 and the negative vertical sync to pin 14.  I plugged it all in and the monitor blew a fuse.  I replaced the fuse and tried plugging in the monitor without the hack connected.  It blew the fuse again.
My monitor is a WG k7131 and is set up with a separate ground pin next to the negative sync pins.  Should I have connected that ground to pin 10?  Can someone tell me what I did wrong and/or how to fix this constant fuse-blowing?
"Sure, I could have stayed there.  Could have even been king.  But in my own way, I am king.  Hail to the king baby."
menace
Re:Messed monitor. Any help?
« Reply #1 on: August 24, 2004, 02:57:51 pm »
Sounds like you have a bad part on the monitor and not the cable hack you created.  The signal wires coming in only have 1-5 volts of juice and very few amps, so unless you hooked your RGB to a power bar somewhere i doubt thats what it was.  When my Wg 7193 was blowing fuses, it was a bad flyback.  check out randy fromm's flowchart for your monitor and see where he recommends starting and go from there.
Ash...Housewares
  • Who wants some?!
« Reply #2 on: August 24, 2004, 03:25:40 pm »
Thanks, I'll give that a looksee and test some parts...
Ash...Housewares
  • Who wants some?!
« Reply #3 on: August 24, 2004, 05:01:18 pm »
How can I tell if my monitor has a built-in isolation transformer?
Ken Layton
  • Guru
  • Technician
« Reply #4 on: August 24, 2004, 06:12:10 pm »
Your k7131 (a.k.a. the k7000 series) REQUIRES AN EXTERNAL ISOLATION TRANSFORMER connected to it.
