Author Topic: Setting all Mame games to 640 x 480  (Read 2591 times)
Halo
  • Last login:April 26, 2005, 03:00:03 am
  • I'm a lamer!
« on: August 24, 2004, 09:36:03 am »
I think I remember someone saying it's posssible to set all games in Mame to the same resolution using the Mamewah setup program. If this is possible .. where do I do this? If it's not possible, is there any other way of doing it?
Also, is there a way of removing the prompt screens before the games? I'm using the Win32 cmd line version of Mame.
Thx :)
A stone falls on the pot, woe to the pot. A pot falls on the stone, woe to the pot. In both cases it is bad for the pot.
Lilwolf
  • Last login:May 04, 2026, 07:14:03 pm
Re:Setting all Mame games to 640 x 480
« Reply #1 on: August 24, 2004, 10:35:40 am »
I'm not sure through mawah
but in the mame.ini (if you don't have an ini file... mame -cc to create it)
resolution = 640x480   <--- think its resolution.. at work and cant double check it.
but a better solution in my mind is if you dont' want it to change... set windows to 640x480 and tell mame it cant change the resolution or bpp (switchres and switchbpp I think... change them to 0)
« Reply #2 on: August 24, 2004, 11:33:40 am »
Yep, no '=' tho:
resolution 640x480
Halo
  • I'm a lamer!
« Reply #3 on: August 24, 2004, 01:03:41 pm »
Thank you both :)
Halo
  • I'm a lamer!
« Reply #4 on: August 24, 2004, 02:43:59 pm »
I typed in 'mame -cc' at the cmd prompt, it came up with the message 'mame is not recognised as an internal or external command'
« Reply #5 on: August 24, 2004, 02:48:27 pm »
Navigate to your mame folder first (not been paying attention in DOS class eh?? ;) )
eg if mame.exe is in c:\mame, type:
c:
cd\mame
mame -cc
Halo
  • I'm a lamer!
« Reply #6 on: August 24, 2004, 02:49:54 pm »
Ahh missed a bit! It says ....
'is not recognised as an internal or external command, operable program or batch file'
Halo
  • I'm a lamer!
« Reply #7 on: August 24, 2004, 02:52:51 pm »
Ahhhh I see .. thanks!
I actually just ordered 'dos for dummies' from the cut price book store (honest). I did ask them though if they had anything a little simpler hahaha.
