Author Topic: Buck rogers cab dimesions  (Read 1259 times)
atari2600chick
  • Last login:November 08, 2011, 07:12:19 am
    • GamesVille
« on: August 23, 2004, 10:49:36 pm »
I was wondering if anyone has measurements for a buck rogers sit down cab. I have read other threads and found the following measurements (which have been very helpful - thankyou!!)
QUOTE: Started by Felsir, Message by Rocky
Here's the measurements for the Buck Rogers sit down:
(I used Tailgunners' drawing)
A:  9.5" in front, 8.5" at the back
B:  16.25" to the base of the pedal, 25.5" to the end of the floor area
C:  19"  (but the CP has a trigger stick)
D:  27.5"
E:  3"
Sorry I don't know how to post the pic/or the thread/s that goes with this post.
I was wondering if anyone had any other measurements like:
length,
depth
and height of the cab
dimesnions of monitor enclsoure (ie height from D to top)
arm rest side dimensions
I think I would like to base a driving cab on a similar design, so any help any one could give would be much appreciated  ;D
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
Re:Buck rogers cab dimesions
« Reply #1 on: August 24, 2004, 02:31:52 am »
I might be able to help you, if I can find someone online who is willing to measure it for me.  Give me a few days.
By the way, are you talking about the fully enclosed cockpit?
« Last Edit: August 24, 2004, 02:33:53 am by Jakobud »
atari2600chick
    • GamesVille
« Reply #2 on: August 24, 2004, 06:57:20 am »
I wasn't referring to the enclosed cockpit. There is a cab that has the monitor enclosed and seat attached. I will try to add a pic.
Jakobud
« Reply #3 on: August 24, 2004, 02:53:10 pm »
Ah, this one
That one is a little more rare I think, but I'll still look around.
Rocky
« Reply #4 on: August 25, 2004, 12:03:48 pm »
I have a Buck Rogers sit down (not enclosed) that I'm working on.
IMO it is ideal for a sitdown cab design. It is really 2 pieces. The seat is small and light enough that I can lift it by myself and carry it (not recommended for stairs). The monitor / PCB / CP section is about the size of a Mini-cabinet.
atari: I'll get the measurements you asked for and post back here.
Rocky
Rocky
« Reply #5 on: August 28, 2004, 12:49:25 pm »
atari2600chick,
I'm working with Jakobud so he can create a complete set of plans for the Buck Rogers sitdown.
In the mean time, here are the dimensions you asked for:
Length
   At bottom -- 56"
   At its longest point (near the top of the seatback) -- 64"
Depth (I'm guessing width?)
  27 5/8" wide (outside dimensions)
Height of cab
  38" at top of seat back
  18" at arm rest
  33 3/4" at back door
  47" above monitor (after 45 degree angle)
  50" at front edge of monitor encloser
Monitor encloser
  26 1/2" wide x 19" high
  (monitor is offset in the encloser)
Arm Rest
  7" wide (exterior dimensions)
  9" long (for monitor piece of cabinet)
  25 3/4" long (for seat piece of cabinet)
Seat
  20 3/4" wide including right side piece
  20 1/8" wide for just the seat
I hope this gives you some ideas. I think Jakobud will have some plans soon. We still have to exchange some more information before he can do them.
Good luck,
Rocky
