Author Topic: Springs  (Read 1177 times)
Squirrely
  • Last login:August 24, 2004, 08:55:35 am
Springs
« on: August 23, 2004, 03:38:44 pm »
I need a few springs between 4 and 5 inches in diamiter, no shorter then 1 inch, and not really strong, about 4 or 5 pounds when pressed.  Anyone know where I might find something like this?
Come to think of it I might be able to make some out of a clothes hanger or soemthing.  But it would be nice to have pre-made springs.
pcates
  • Last login:January 05, 2011, 08:15:57 pm
Re:Springs
« Reply #1 on: August 23, 2004, 11:00:45 pm »
I just found a bunch of springs at my local ACE Hardware. They had a ton of different sizes. Home Depot and Loews have like 4 springs. So, I would try a small hardware if you can still find one.
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
Re:Springs
« Reply #2 on: August 23, 2004, 11:16:01 pm »
4-5 inches in diameter is somewhat large, especially if you are looking for something pliable enough for a dance mat.  also, anytime ive used wire to try to make a spring, it never kept its shape or tensile strength.
i believe you should do more research into how others approached this.  i believe foam/polymers is a viable option.  you could also try using multiple small springs as well..
boesiii
  • Last login:November 22, 2015, 07:56:14 am
Re:Springs
« Reply #3 on: August 24, 2004, 12:26:40 pm »
Try an auto parts store, they will probably have bigger springs compared to a local hardware store.
boesiii
Re:Springs
« Reply #4 on: August 24, 2004, 12:29:38 pm »
Maybe try an old box spring mattress.
