Author Topic: xbox keyboard/controler relationship  (Read 2635 times)
Squirrely
  • Last login:August 24, 2004, 08:55:35 am
« on: August 22, 2004, 04:51:28 pm »
I am building a dance pad for use with my xbox and I need the smallest way to hook up all the wires (hacking a controler is a little big).  I am concidering using a usb adapter and hacking a keyboard as their insides are smaller then controlers'.  However I want it to work with original xbox games as well as stepmania.  Are the up, down, left, right, a, b, x, y, start, and back buttons on the controler directly related to keys on a keyboard?
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:xbox keyboard/controler relationship
« Reply #1 on: August 23, 2004, 12:36:56 pm »
Original xbox games have no keyboard or mouse support (even if you use the usb adapter)...sorry.  You'd have to either hack pads or buy original ddr pads.
Squirrely
« Reply #2 on: August 23, 2004, 03:32:05 pm »
well...  that sucks.  Then what's the easiest controller to hack?
Dave_K.
    • Arcade Fever
« Reply #3 on: August 23, 2004, 04:19:00 pm »
Madcatz pads are usually the easiest.  But if you use multiple consoles, the easiest is to hack PSX (or even the h-series PS1 DS pads) and then use a converter for whatever console you have (also works with PC if you use a usb converter).
