Author Topic: Project64 Full screen immediately after loading rom?  (Read 10123 times)
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
« on: August 22, 2004, 03:14:50 pm »
Can anyone tell me how to get Project 64 to go full screen immediately after loading a ROM? (I'm using MAMEWAH)
Clicking Options > Full Screen / pressing ALT+Enter gets old very quickly :(
I've gone through all the options and I can't find any command line params in the help.
« Last Edit: August 22, 2004, 03:25:21 pm by DaveJ-UK »
Halo
  • Last login:April 26, 2005, 03:00:03 am
  • I'm a lamer!
Re:Project64 Full screen immediately after loading rom?
« Reply #1 on: August 22, 2004, 04:39:39 pm »
Dave ..  this is from memory, so don't quote me on this. I think what I did was open P64 directly from the .exe, then right click to bring up the options .. then set full screen from there. Then, close it down and try it from Mamewah. I'm using the same combination, and Im 99% sure this is how I did it.
TJ
A stone falls on the pot, woe to the pot. A pot falls on the stone, woe to the pot. In both cases it is bad for the pot.
DaveJ-UK
  • Dirty Dawg
    • ChronicGames.NET
« Reply #2 on: August 22, 2004, 06:17:44 pm »
I'm sure I did this, but i'll give it another try. In fact, I'm quite certain it doesn't work because I've launched a game (from MAMEWAH), played it for a bit, hit escape, loaded another game, and it's windowed again!. I'll give it another try all the same.
wj2k3
  • Last login:August 22, 2006, 12:23:48 am
  • Not!
« Reply #3 on: August 23, 2004, 09:32:43 am »
Under the 'Options' menu, choose 'settings...'   (or use ctrl+T)
Then select the 'Options' tab
Then check the box next to "On loading a ROM go to full screen"
click "OK" and you are good to go.
-wj2k3
DaveJ-UK
  • Dirty Dawg
    • ChronicGames.NET
« Reply #4 on: August 23, 2004, 01:21:05 pm »
Thanks a ton wj :)
I was looking under video options; didn't even see that menu! Opticians first thing in the morning then :D
