Author Topic: Arcade Monitor Picture Issues  (Read 1641 times)
GameDork
  • Last login:March 06, 2011, 07:56:45 pm
  • I installed a DDR Pad on Tom Cruise!!
« on: August 21, 2004, 06:21:04 pm »
     I have a Wg4903 that has a great picture, but when there is bright colors ( mostly white) the screen looks wavy on the left side. I tried to take a pic but they would never turn out good. Does it need new caps.?
    Also I have a little "tearing" at the top of the screen. It doesn't really bother gameplay but I am just curious why its doing this.
Donkey Kong Hi Scores:
1) 169,600
2) 164,300
3) 134,000
4)116,800
5) LOL!
MonitorGuru
Re:Arcade Monitor Picture Issues
« Reply #1 on: August 21, 2004, 08:46:03 pm »
Bent lines: Typical problem of a weak power supply.
Nearly all consumer TV sets exhibit this problem to some degree, most cheap ones really significantly "bloom" and more so, bend vertical lines, especially on the bottom 1/2 of the display on the far left and far right of the screen, the more white there is displayed on the screen.   (White takes the most power as all 3 guns are firing at full intensity, lessing the amount of power available to control geometry and other things)
It might be fixable to some extent by replacing every electrolytic cap, including the large filter capacitor (that is not part of a normal cap kit), but probably one or more transistors are not performing as well or other components may be weakend due to age.
Ken Layton however might have more info on this particular model.
Tear:  Older arcade monitors typically don't sync well with new computer VGA cards (and sometimes certain arcade game boards) and can show tearing.  Sometimes cap kits can help, but many times you may not be able to fix it from what I've read.
« Last Edit: August 21, 2004, 08:48:49 pm by MonitorGuru »
Ken Layton
  • Guru
  • Technician
« Reply #2 on: August 21, 2004, 11:26:57 pm »
If the monitor has not had a capkit installed recently then install one first. After that's done then see how the picture looks.
