Author Topic: Mapping a mouse click to a button/key?  (Read 1973 times)
Xynie
  • Last login:July 13, 2020, 09:30:19 am
  • Sometimes, I feel like Dilbert.
« on: August 20, 2004, 10:53:23 am »
OK, I have been trying to figure this out for a while, and I don't know if I am searching with the wrong keywords or what, but I figure this has been addressed before.  I even went through the FAQ, and all I saw was... "Yep, I use a trackball as a mouse" :)
Anyways, I have a trackball I want to use as a mouse, which is working fine.  I do not however have left mouse click mapped to anything, which I need to do.  However, I can't find anything that will allow me to map a button on my CP to the left click... Is there a port of the Ipaq I missed?  Or is there a piece of software I have to use to emualte the click with a keyboard button?
Thanks for the help.
Anthony
_Iz-
  • Last login:June 14, 2026, 11:04:13 pm
  • Time to coin up!
Re:Mapping a mouse click to a button/key?
« Reply #1 on: August 20, 2004, 10:56:38 am »
Anthony
You don't map the mouse click in the I-Pac or it's programming software. You have to configure the specific emulator/game/program you're using to use the mouse buttons as actions.
Xynie
« Reply #2 on: August 20, 2004, 11:12:32 am »
Anthony
So, in the case of Windows XP in my cabinet, the only choice is using the Mousekeys accessibility program?
Anthony
_Iz-
  • Time to coin up!
« Reply #3 on: August 20, 2004, 11:36:28 am »
Ahhh, I think I'm beginning to understand. You have a trackball but you have no physical mouse buttons connected to the trackball interface. You want to use a button connected to the I-Pac to simulate a mouse click for use in windows right?
Can you connect buttons to your trackball interface? (is there a physical location to make the connection)? You could disconnect 1 or 2 buttons from the I-Pac and connect them to the trackball interface instead. Then map the software/game/emulator to recognize mouse clicks instead of keystrokes for those buttons.
_Iz-
  • Time to coin up!
« Reply #4 on: August 20, 2004, 11:38:03 am »
Xynie
« Reply #5 on: August 20, 2004, 11:42:33 am »
That is EXACTLY what I ment  ;D
Thanks very much for the help.
Anthony
