Author Topic: ms-dos file extractor  (Read 1867 times)
Dexter
  • Patriotism, the last refuge of the scoundrel. -- Irish, darnit!
  • Last login:February 01, 2024, 04:36:19 pm
  • "MAKE POVERTY HISTORY......."
« on: August 20, 2004, 09:33:58 am »
Hi all,
Theres a small program floating around that extracts the necessary ms-dos files from a windows 98 install to allow a hard drive to boot to dos.
Can anybody point me in the right direction??
Dexter
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
Re:ms-dos file extractor
« Reply #1 on: August 20, 2004, 09:47:05 am »
This isn't what you're talking about, but do you think it would work for you?
http://www.bootdisk.com/bootdisk.htm
Dexter
« Reply #2 on: August 20, 2004, 10:14:19 am »
IIRC it was downloadable from a site that had cabinet plans on it, including a bartop arcade jobbie.
Dexter
mp2526
  • Last login:August 11, 2023, 02:30:47 pm
    • Miavio
« Reply #3 on: August 20, 2004, 10:30:20 am »
I know exactly what you are talking about, I had to do it the other day to fix a problem a friend was having with her laptop, however I can't remember the link.  I did find a few links that describe just changing a few lines in a file that may help.
http://www.ecotton.com/kbase/Win9598_boot_MS-DOS.htm
http://www.annoyances.org/exec/show/article01-412
I actually had to replace some files when I did it, but this might work.  If I remember the site, I'll post it.
Dexter
« Reply #4 on: August 20, 2004, 10:34:13 am »
This program allows a boot drive to have no windows install and boot to ms-dos (7 I think)
I think it just copies over files from a windows boot drive?
krick
  • Gotta have blue hair.
« Reply #5 on: August 20, 2004, 10:45:31 am »
Do you want the drive bootable or do you want all of DOS on the drive?
Most of the stuff that is installed as "DOS" is useless nowadays and a waste of drive space.
I don't see the point.
Making the drive bootable is easy....
Start with a windows 98SE boot disk.
boot with that disk
run Fdisk to create/delete partitions on your hard drive as necessary
reboot computer (leaving boot diskette in)
run format on your hard drive like this...
FORMAT C: /S /U
the "S" switch transfers the "system" to the hard drive making it bootable
the "u" switch performs an "unconditional" format which fills the drive with zeroes
(the "u" is not mandatory but I like to do it anyway)
then remove your boot disk and reboot the computer
Here's a link that shows how FDISK works....
http://www.perfectdrivers.com/howto/fdisk-format.html
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
_Iz-
  • Last login:Today at 12:03:23 pm
  • Time to coin up!
« Reply #6 on: August 20, 2004, 10:48:40 am »
Hi all,
Dexter
I have it at home (I'm at work right now). This is the closest I can find on the internet...
http://www.mvps.org/dts/WinME_DOS/Win-ME.htm
    Good Luck!
Dexter
« Reply #7 on: August 20, 2004, 10:55:37 am »
I actually have arcadeos, mame and roms on the drive (currently a secondary drive). I need to make it bootable to arcadeos after I swap the jumper to make it the primary drive.
_Iz-
  • Time to coin up!
« Reply #8 on: August 20, 2004, 11:00:57 am »
The drive will have to have been partitioned as a primary partition and made active before you can boot from it. (This may or may not be the case already depending on how it was setup originally)
Dexter
« Reply #9 on: August 20, 2004, 11:03:53 am »
Will fdisk across and check it out......
Cheers for the info!
