Author Topic: Do I need an isolation transformer?  (Read 1686 times)
Trimoor
  • Last login:November 18, 2006, 09:01:46 pm
  • I like shooting out of helicopters.
    • Trimoor
« on: August 18, 2004, 02:33:56 pm »
I have a Nintendo 20-z2AW monitor, but I don't know if it needs an isolation transformer.
The manual says nothing about it, so I don't know what to do.
I don't really have one to spare, so I'd like to know.
Any ideas?
MonitorGuru
Re:Do I need an isolation transformer?
« Reply #1 on: August 18, 2004, 03:14:23 pm »
Don't anyone take this the wrong way, but if you have to ask, you should :)
Running a monitor with an isolation transformer that doesn't require one won't hurt anything.
Running one that does require it without one, will hurt the monitor, the game board, your fuses or yourself.
But to specifically answer your question, yes, the Nintendo monitors require an isolation transformer...   **** BUT **** not just any old isolation transformer, they require a STEP-DOWN isolation tranformer.
They're built in Japan for japanese voltages which are 100 volts and not 110-120 like they are in the US.  If you connect it without reducing the voltage to 100 volts, you will blow it up (a few key components will fry on the monitor chassis).
You will need a 1.1 : 1 step down AC isolation transformer in order to run a Nintendo monitor.  Get one out of an old Nintendo cabinet.
Trimoor
    • Trimoor
« Reply #2 on: August 18, 2004, 03:27:57 pm »
Uh, and just where am I going to get an old Nintendo cabinet?
I have exactly one isolation transformer, currently in use, and have no idea what ratio it is.
shadowdrak
  • Last login:November 20, 2005, 04:59:54 pm
  • I'm still a llama!
« Reply #3 on: August 23, 2004, 06:09:41 pm »
I suggest you buy one for this purpose from an electronics company(search google).  no offense, but have you thought of testing the transformer you have with a multimeter?  just connect the transformer you have to the wall and read its output voltage.  If it is a transformer from a US cab it is probably a 1:1 ratio though.  If you don't have a multimeter, then go by one.  If you don't want to buy one, then, sorry, I can't help you.
