June 15, 2026, 07:09:11 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Video Games
through our link. Thank you!
In 2027, BYOAC hits 30 years old.
It started in 1997
. It has cost saint somewhere between $25,000-$30,000 to host in its lifespan.
Main
Main Forum
Had a brainstorm...
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Had a brainstorm... (Read 1885 times)
vader
Trade Count:
+1
Full Member
Offline
Last login:December 27, 2025, 08:14:42 pm
I can't breathe in this thing !!
Had a brainstorm...
on:
August 17, 2004, 09:40:56 pm »
and I use that word lightly......can I just tap into the power on the interface board on the USB Happs trackball to power the led light for the translucent ball....if I remember correctly, usb supplys 5 volts so this should work......I think
Tim
Logged
paigeoliver
Trade Count:
+2
Full Member
Offline
Last login:May 19, 2026, 08:29:24 pm
Awesome face!
Re:Had a brainstorm...
Reply #1 on:
August 17, 2004, 09:44:19 pm »
Tap into your power supply instead, as the USB bus has a limited amount of 5volt power.
Logged
RayB
I'm not wearing pants! HA!
Trade Count:
+4
Full Member
Offline
Last login:August 18, 2025, 10:59:20 pm
There's my post
Reply #2 on:
August 17, 2004, 10:55:39 pm »
a 13v light, tapped into your PS's 12volt line will probably be brighter than a 5v light.......
(but I'm no expert so I shouldn't be adding my 2 cents here.
Logged
NO MORE!!
Bgnome
Trade Count:
0
Full Member
Offline
Last login:January 10, 2005, 04:05:16 pm
Who's da gnome?
Reply #3 on:
August 17, 2004, 10:56:02 pm »
its doable, but you have to worry about whether or not you will be using other usb devices. if you hook it into a powered usb hub, you wont have to worry as much..
Logged
DaveMMR
Trade Count:
0
Full Member
Offline
Last login:April 28, 2025, 11:33:13 am
Reply #4 on:
August 17, 2004, 11:12:49 pm »
It's probably better to put the power supply at risk of shorting than the USB ports and the motherboard (as is my understanding).
(I'm no expert either, just reciting what I learned from others).
Logged
TeeVee GAMES
fredster
Grand Prophet of Arcadeology
Trade Count:
+1
Full Member
Offline
Last login:February 16, 2019, 04:28:53 pm
It's all good!
Reply #5 on:
August 18, 2004, 12:12:17 am »
Is that so you wouldn't have to run a wire except for the USB from the trackball to the PC?
Logged
vader
Trade Count:
+1
Full Member
Offline
Reply #6 on:
August 18, 2004, 12:23:13 am »
Exactly....that is what I wanted to accomplish.....but if it will cause problems, I can do it the way others are suggesting.......I definitely go with a high wattage bulb if I have to run the power wire....
thanks all
Tim
Logged
chrisindfw
Trade Count:
0
Full Member
Offline
Last login:May 09, 2020, 05:57:34 pm
I drank what?
Reply #7 on:
August 18, 2004, 08:27:47 am »
I was wondering the same thing to power my 5v lcd panel...
There are two pins on the IPAC that supply power and a ground...
If you are using an IPAC, try getting power from there.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
Had a brainstorm...
