Author Topic: Decent MAME Spinner?  (Read 10292 times)
SQrL
  • Last login:November 24, 2014, 02:00:29 pm
  • The Game is Never Over!
« on: August 17, 2004, 06:08:15 pm »
Looking for a fairly cheap solution for adding Spinner(s) to my control pannel.  Did a little searching and ran across these: http://www.mamespinner.com
Anyone know if they are good?  Also, how easy is it to setup seperate analog controls in MAME (spinners, trackballs).  I currently have a HAPPS 3'' USB trackball connected.  So I'm assuming spinners will be added to my OS (win xp pro) as mouse2 & mouse3.
thanks for any input (sorry for the n00b spinner question  ::))
NoOne=NBA=
Re:Decent MAME Spinner?
« Reply #1 on: August 17, 2004, 06:35:45 pm »
I haven't used those; but, from the descriptions they give, I'm guessing that they are not weighted like the Oscar and SlikStik ones.
That may be OK for paddle games like Arkanoid, but will probably feel wrong for games like Tempest/Tron/Star Trek/etc...
I would suggest going the extra $4.00 to get an Oscar Model 3, and using your existing trackball interface to do a dual connection, as shown here on Oscar's website.
It will be $10.00 more than the MAMESpinner one if you throw in a rubber knob, but I think you'd be much happier with an Oscar one.
As far as setting them up, you are going to need to go with a MAME version that supports multiple mice, like MAME Analog+.
Goz
  • KOTA
« Reply #2 on: August 17, 2004, 07:03:24 pm »
I've used the spinner from mamespinner.com and they are not weighted. They work fine for games like arcanoid and alike games. But I too would suggest going going for the Oscar. The steering wheel attachment from mamespinner.com is a cool idea and the spinner would work well for car games like champ sprint.
Hope this helps,
-Goz
daveg2000
  • Last login:January 02, 2009, 08:55:51 pm
  • PSP? Yeah right. GP2X Baby! This thing is awesome
    • www.davegrams.com
Re: Decent MAME Spinner?
« Reply #3 on: February 26, 2005, 02:17:56 pm »
Has anyone used got one of these spinners since they
now have more weight to them?
Just curious.....
...so I will ask you... "Deal, or No Deal?"
spystyle
« Reply #4 on: February 26, 2005, 07:02:58 pm »
I was working with the Cheep Spinner design and came up with a way to build it for $10, it works a treat! I took a pic with description that illustrates assembly here:
http://tinyurl.com/y35kl6
Nathan Strum was really on to something when he discovered the porch door roller bearing and the construction tie plate, the bearing spins awesome and 2 can be had for $5 at Home Depot. And the tie plate is a perfect solution to making a "non-flanged bearing" mountable in wood, costing only 50 cents!
Weld is perfect, solder also works (big solder, like used to attach metal parts) perhapse silver solder (as used in plumbing with a torch) or JB Weld (amazing cold weld but make sure to rough the surfaces up major with 60 grit or gouges with a dremmel so the JB Weld has something jagged to grip to)
Or I bet your local mechanic would weld it for you for a few bucks.
For the mouse guts and encoder wheel I'd recommend following Nathan Strum's Cheep Spinner tutorial :
http://www.arcadecontrols.com/files/Miscellaneous/spinner.pdf
(or just do a sloppy mouse hack like I did)
I call it the Cheep Spinner Lite!
Dig it?
Craig
« Last Edit: December 09, 2006, 12:40:39 pm by spystyle »
daveg2000
    • www.davegrams.com
« Reply #5 on: February 26, 2005, 08:09:08 pm »
Looks like a good cheap solution.
I'm trying to avoid hacks and things of the such if I can.
Not cause I can't do it... just that I want to
take the easy way out this time around... and just
plug in a usb cable if possible.
I see a $12 part, that takes time to construct
equal to a $40 part that you have to order and wait for a week
for.   For the extra $28... Id rather rather just be lazy.
(until my wife finds out  ;)  )
Then I'll be building the cheap stuff.. ha ha!
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #6 on: February 26, 2005, 08:17:27 pm »
Awww thats not the way to think about it :P  This is people building their own cabinets and controllers, hence BYO, at least consider it.  If you think about it, the $28 this time, and then the few bucks next time, with the cash you save, you can buy better joysticks or siding or something.  Consider it :)  BTW, nice spinner!  I saw one on a site...lemme get it....http://home.t-online.de/home/stephan.hans/tricks.htm#SPINNER%20for%20superduperarcadeconsole.  This place has a few circuits and stuff, I was going to build the two mouse two keyboard one until I found out how hard it is to find a solderable PS2 port :P
daveg2000
    • www.davegrams.com
« Reply #7 on: February 26, 2005, 08:37:23 pm »
Oh...  :o
I thought it was "BUY your own arcade controls"
heh
Okay... I guess building isn't COMPLETELY out of the question...
And if it does turn out good, I definaltely would be more
proud of myself for what I have done...
decisions, decisions....
cholin
    • Nilok Productions
« Reply #8 on: February 26, 2005, 08:57:27 pm »
Thats the spirit!  And you figure, if you were GOING to spend the extra couple bucks, and you fail with your mouse hack / custom spinner, you can easily use the money to try again or just order one and you only lost a little bit, and youll feel better for trying :D  Plus, never know what people will buy now a day!
spystyle
« Reply #9 on: December 09, 2006, 12:44:29 pm »
Is it just my browser - or did Cholin post twice in this thread - yet his post total is "1"
fatfingers
  • Got UltraStiks?™
« Reply #10 on: December 09, 2006, 03:35:52 pm »
Those posts are so old that what you're seeing can probably be accounted for by the half-life of a post!
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
spystyle
« Reply #11 on: December 09, 2006, 05:30:03 pm »
What is half life of a post?
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #12 on: December 09, 2006, 05:36:54 pm »
About 1/4 that of Uranium235
This stuff is now so out of date that the original site listed has been taken over by Spammer Cyber Napping Scum, and the rest of the information is pretty much completely wrong.... except for the cheep spinner...
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
spystyle
« Reply #13 on: December 09, 2006, 06:01:43 pm »
Anyway, back on topic of building a good, inexpensive, spinner.
I made an encoder wheel for my first spinner using a 3" hole saw and sheet metal. To do this I cut a 3" circle (which has a 1/4" center hole) out of sheet metal, attached the encoder wheel template which was printed on sticker paper, and cut the notches with a dremmel.
But this encoder made of sheet metal was flimsey, a thicker sheet metal would have been difficult to cut, and either way an expensive hole saw and arbor must be used. While that is fine for me, because I have that, it would not be cost effective for someone who doesn't have that.
So I started thinking of where a person could get a 3" circle with a 1/4" center hole - it had to be rigid yet easy to cut - viola! A mini CD with a washer in the middle! A mini CD is 3" in diameter (8cm), but it has a 15mm center hole. I found a flat washer that measures 14.5mm O.D. (0.56") and 1/4" I.D. at the hardware store. "USS Flat Washer #10 by Midwest".*
I was curious if a CD could be cut with a dremmel's cutting disk so I cut notches into one. It worked fine and did not crack. I had to sand it after but the whole thing took a leisurely 10 mins to make.
The washer would have to be glued in the middle - I will tape the washer in place from top, flip the disk over, and apply superglue around the outside of the washer.
Once finished i will spray paint the CD flat black
When the spinner is done it will only have cost about $10 :)
What do you think?
Cheers,
Craig
*note, Midwest makes 2 different #10 flat washers, one of them does not have the correct O.D. (outer diameter)
Fozzy The Bear
« Reply #14 on: December 09, 2006, 07:27:48 pm »
What do you think?
Cheers,
Craig
Cool !!! That's what this forum is all about.... a bit of inovation and do-it-yourself stuff. It's kind of gone out of the window here in the last few years, with people just assembling stuff from off the shelf parts more often than not. I'd guess you could get a lot more teeth onto that wheel by using a slitting saw in the dremel instead.
Best Regards,
Julian (fozzy The Bear)
spystyle
« Reply #15 on: December 09, 2006, 07:36:16 pm »
Howdy Fozzy,
Nathan Strum recommends 40 teeth on a 3" circle.
Cheers,
Craig
Fozzy The Bear
« Reply #16 on: December 09, 2006, 07:41:04 pm »
Yeah, that's true.... but given that if you use a mouse hack, the mouse teeth are closer together than that, then you can create a disk with a much higher resolution. The higher the resolution the better! Mame can scale the input to suit the game you want to play.
Best Regards,
spystyle
« Reply #17 on: December 09, 2006, 07:50:04 pm »
In his guide he claims that too many teeth can create a problem for mouse hacks. Apparently mice are not designed to move so quickly, so they would not be able to process the amount of signals from a very fine wheel moving fast. He claims it can create a "strobing effect" and the mouse curser doesn't move, or floats slowly backwards.
But he provides 2 other templates in his guide so you could test all 3 if you like.
Cheers,
Craig
Fozzy The Bear
« Reply #18 on: December 09, 2006, 08:14:14 pm »
I've been doing mouse hacks for a while Craig.... It really depends on the mouse you use. Some are better than others. You need to experiment to find the best resolution you can force on any particular mouse and try different mice.  40T in current terms is very low, and you will find that some games are unplayable with only that many teeth.
The best mouse I found yet was a really cheap £2 one in a supermarket. Beat the pants off the £20 microsoft one I tried.
Best Regards,
spystyle
« Reply #19 on: December 09, 2006, 08:22:27 pm »
I see,
I guess I will try all 3
Cheers,
Craig
Chris
    • Chris's MAME Cabinet
« Reply #20 on: December 10, 2006, 03:30:19 am »
Do you have any suggestions?  USB ball mice are hard to find these days.  Are Logitech's still considered unusable?
--Chris
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #21 on: December 10, 2006, 05:51:31 am »
Aren't logitechs "claimed unusable" only for hacking it to connect a trackball or spinner to it? In this case the mouse will become the spinner so wouldn't every (ball) mouse work?
Fozzy The Bear
« Reply #22 on: December 10, 2006, 06:50:08 am »
Shop around a bit..... I picked up a USB Ball mouse for £2 from the local supermarket and it came with a USB to PS2 converter.
There doesn't seem to be any shortage of USB mice.
In any case, it doesn't have to be a USB Mouse. You can do exactly the same with a PS2 Mouse..... you can even plug a PS2 mouse into a serial port instead by using a PS2 to Serial converter plug.
Best Regards,
« Last Edit: December 10, 2006, 06:56:07 am by Fozzy The Bear »
Fozzy The Bear
« Reply #23 on: December 10, 2006, 06:52:59 am »
Any ball mouse will work.... but it's a question of how well they work. Some work much better than others at reading the disk. It depends how good the optic board in the mouse is. You have to try a few different ones until you find a really good one.
Best Regards,
spystyle
« Reply #24 on: December 10, 2006, 11:36:59 am »
Fozzy,
Who manufactured this "supermarket mouse" that you recommend?
Cheers,
Craig
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #25 on: December 10, 2006, 12:40:14 pm »
I was responding more to the "unusable" that Chris mentioned. I remembered the same, but I think only in connection to using them as optic boards for trackballs (i.e a mouse hack). But anyway, nevermind I guess.
More on topic, I was wondering if one could use a overhead projector film with a wheel laser-printed on it and stick that to a acrylic wheel or something? Would be easier than perfectly cutting out the teeth yourself and you could get a pretty high teeth count with a laser print too.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #26 on: December 10, 2006, 03:31:09 pm »
I'm pretty sure I've seen projects with encoder wheels just printed out onto transparency film.
Logitech mice are fine to hack with this method; where you're using the existing mouse optics.  Logitech mice are unsuitable for the other mouse hack type; where you're de-soldering the mouse optics and wiring external optic boards to the mouse, as in the case of hacking a mouse to interface a trackball.
spystyle
« Reply #27 on: December 10, 2006, 03:56:39 pm »
OK, I made the encoder wheel as planned.
I printed the template out onto sticker paper, stuck it to a mini CD, glued the #10 USS washer in the middle (applying glue to the outer edge of the washer only, none in the washer's center hole), I let the glue cure for 12 hours, then cut the CD with the dremmel, then sanded and spray painted it with flat black paint.
The washer stayed in place even when I was cutting, sanding, and flexing the cd - it is permanantly affixed.
This is an encoder wheel anyone can easily make :)
Cheers,
Craig
« Last Edit: December 10, 2006, 04:04:16 pm by spystyle »
spystyle
« Reply #28 on: December 10, 2006, 04:09:06 pm »
and to recap, here is the spinner plan
« Last Edit: December 10, 2006, 06:24:18 pm by spystyle »
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #29 on: December 10, 2006, 06:20:44 pm »
maybe I missed it somewhere, but why not just use the encoder wheel from the mouse itself?
spystyle
« Reply #30 on: December 10, 2006, 06:25:34 pm »
Because it would be too easy!
*just kidding*
I really don't know. I made my own spinner based on the "Cheep Spinner" which uses a 3" encoder wheel.
Here is a page with slew of spinners, they all have, what looks like 2" and larger wheels:
http://www.retroblast.com/reviews/roundup.html
The Tempest spinner looks like a 4" wheel (you could make that from a regular CD instead of a mini)
Cheers,
Craig
« Last Edit: December 10, 2006, 06:38:24 pm by spystyle »
Zeppo
  • Last login:February 14, 2024, 10:26:44 am
  • Greetings Program!
« Reply #31 on: December 10, 2006, 07:13:10 pm »
So, how does it play?
Z
SithMaster
« Reply #32 on: December 10, 2006, 07:24:34 pm »
im probably going to build one just for the fun of it.  i just need to buy a mouse.
yes how does it play?  considering weighing down the bottom perhaps.
spystyle
« Reply #33 on: December 10, 2006, 07:56:52 pm »
It plays well :)
As for weight, it has plenty of weight provided by the dozen fender washers.
Cheers,
Craig
Fozzy The Bear
« Reply #34 on: December 10, 2006, 09:36:52 pm »
Fozzy,
It was an ASDA own brand one.... but that was over 12 months ago, so you may not find the exact same mouse in there now.
The best bet is to try a few cheap mice to see what works out.
Best Regards,
DrumAnBass
  • Last login:July 10, 2024, 10:36:54 pm
  • "I love this computer magic!" - Viv Savage
« Reply #35 on: December 10, 2006, 10:25:15 pm »
For my hard drive hack spinner I used the encoder wheel from the mouse I hacked and it seems to be great...  The mouse I used is similar to this:
http://www.geeks.com/details.asp?invtid=HTM-50W&cat=MOU
For the knob I used half a yo-yo.
"Some drink from the fountain of knowledge; I only gargle."
spystyle
« Reply #36 on: December 10, 2006, 11:05:27 pm »
« Last Edit: December 11, 2006, 09:04:22 pm by spystyle »
spystyle
« Reply #37 on: December 11, 2006, 08:30:20 am »
Fozzy,
Best Regards,
Was the PCB labeled? Do you have links or pics of your spinners?
Cheers,
Craig
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #38 on: December 11, 2006, 11:26:02 am »
That is far out! I wonder why all the other spinners use large wheels? I guess I'll have to try both - I 'spose I could drill a 1/4" hole in a mouse encoder wheel to use in the above spinner and compare the two.
On second thought - I bet they make the wheels larger so they will have more rotations per knob twist. A large encoder wheel will move a greater distance per knob twist than a smaller encoder wheel.
Cheers,
Craig
The only difference I could think of is the size of the teeth. Maybe old fashioned optics could not make out the tiny teeth used in mouse optics. The speed with wich the teeth move past the optics would be the same if you have a large or small wheel. Well maybe not the speed, but the timing of the pulses would be the same (if you keep the same number of teeth).
spystyle
« Reply #39 on: December 11, 2006, 11:56:14 am »
« Last Edit: December 11, 2006, 09:04:41 pm by spystyle »
