Author Topic: MAME32 problems with Athlon64 3200+  (Read 2031 times)
jbeersm
  • Last login:May 13, 2005, 02:53:45 pm
  • Never grow up...
« on: August 16, 2004, 12:28:53 pm »
I installed MAME32 on my new pc that I am putting in my cabinet and have had problems.
MAME32 ver .82 through .84 work fine on all my other PC's but does not on my new Athlon 64 3200+.  The program loads fine and displays all my ROMS.  However when I select a game to play the screen flashs and then goes right back to the main screen.
I tried noname's version of mame32 with odd results.  When I select a game with nonames version the game loads, I type OK and then I get sent back to the MAME32 (nonames version) again.  However, I see another window has been loaded and if I alt-tab over to it I then have my game screen and can play.
Has anyone seen this before?  Is my new PC to fast for MAME32?
Xelotath
  • Last login:December 18, 2010, 11:07:44 pm
    • My Destructoid Blog
Re:MAME32 problems with Athlon64 3200+
« Reply #1 on: August 16, 2004, 01:15:41 pm »
I have the same cpu as you, But I'm using the commandline windows build of MAME. I have no problems running games, and everything play fines(exept unplayable game, and the 3D games that would take a 10Ghz CPU) Try mame instead of mame32 and see if it works.
jbeersm
  • Never grow up...
« Reply #2 on: August 16, 2004, 01:31:35 pm »
I have tried the command line version of mame and it appears to work just fine.  I have been using mame32 because it is easier on the wife and kids to select and play games and easier on me to set up than having to setup a seperate front end.
Xelotath
« Reply #3 on: August 16, 2004, 01:36:17 pm »
I use Mamewah, once it's setup, it's a charm to use. You select with the joystick and hit the button then you play. I find it easier to use than mame32, and it's way prettier with a good skin.
reebboy
  • Last login:December 12, 2005, 01:34:53 am
  • Now its time for some serious insanity!!!
« Reply #4 on: August 17, 2004, 09:00:43 pm »
I've had this problem when I tried to run certain games with with the "Direct 3D" selected. Also sometimes certain configurations/ settings in the "advanced control" menu will cause the same problem.  Many times certain settings that worked for one computer may not work for another.
Dude!!! Where's my game.....
jbeersm
  • Never grow up...
« Reply #5 on: August 18, 2004, 09:49:49 am »
I have tried it with and without "Direct 3D" selected.  In fact I have been through most of the configuration options 1 at a time to see if any setting would help.  So far no luck.
