Author Topic: VirtuaNES  (Read 1096 times)
Halo
  • Last login:April 26, 2005, 03:00:03 am
  • I'm a lamer!
VirtuaNES
« on: August 13, 2004, 09:06:17 am »
Has anyone got VirtuaNES working with Mamewah? I'm having a few minor problems. I have my games list okay, loading screen fine, and I assume I need to 'show dos box'?? I get the little dos box .. and I can click 'Open' from the dos box and load the games right there no problem.
I can't figure out whats missing in between to get it to do the same directly from the Games list.
Also .. should I set the ROM extension to 'NES' as this is the extension in the folder? Or should I leave it to ROM .. and 'ROM only' as the list option?
A stone falls on the pot, woe to the pot. A pot falls on the stone, woe to the pot. In both cases it is bad for the pot.
TalkingOctopus
    • My Arcade
Re:VirtuaNES
« Reply #1 on: August 13, 2004, 10:41:06 am »
This is the extension in the folder so it should be set to NES in the MAMEWAH emu config.
Here are my MAMEWAH settings for VirtuaNES.
Show DOS Box = 0
Send ROM Path = True
Use Long Filenames = True
Send ROM Extension = True
Mapping the escape key to exit (Windows version):
Open virtuanes.ini and change this line:
[ShortCut]
TBL00=18402E4026403140204000000000000017401140000000000000000000002D4012
to this:
[ShortCut]
TBL00=000000000000000000000000000000000000000000000000000000000000010001
Halo
  • I'm a lamer!
Re:VirtuaNES
« Reply #2 on: August 13, 2004, 12:13:41 pm »
Thanks very much! .. off to try now :)
Halo
  • I'm a lamer!
Re:VirtuaNES
« Reply #3 on: August 13, 2004, 01:33:00 pm »
That's great, all working fine .. :)
Just one small thing, when it exits, it shows the desktop edges for a split second before returning to the Mamewah menu .. anything I can do there, or is that a 'live with it' type affair?
Also, I read the layout.txt file and managed to change the layout / graphics for MAME no problem, but the Mamewah GFG file doesn't seem to have any options for the other Emulators .. Where do I go to change the VirtuaNES layout, or must this be done manually? I'm planning more EMUs, so hopefully this will also come in handy for those.
Thanks again.
