Author Topic: Marquee Lighting ???  (Read 1901 times)
MAME nut
  • Last login:March 18, 2024, 12:33:01 am
« on: August 11, 2004, 04:47:36 pm »
I am going to need to replace the fluorescent light behind the marquee in my MAME machine.  Will any fluorescent light from Home Depot work??  My concern is the ballast will cause interference with the monitor, speakers, etc.  I know some lights use a magnetic ballast and other use and electronic ballast....which is better??
Thanks,
SW
JustMichael
  • Mmmmm!! Cheesecake!!
Re:Marquee Lighting ???
« Reply #1 on: August 11, 2004, 05:37:08 pm »
One thing you must consider is space.  Obviously the 4' shop flourescents just aren't going to fit...
I used a couple 18" undercabinet flourescents from Home Depot ($7 each) and they have worked just fine.  The one behind the marquee I had to screw right through the plastic side to get it mounted the way I wanted.
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« Reply #2 on: August 11, 2004, 05:43:04 pm »
I bought the same thing, one undercabinet 18" light from walmart for $6.76 with light. Works fine in both of my cabs
BYOAC users get 5% off with coupon code byoac5
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
« Reply #3 on: August 11, 2004, 08:42:54 pm »
I got cheap a 18" flourescent fro $10 fron ACE hardware works great with no problems.
Gary
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« Reply #4 on: August 14, 2004, 03:54:07 pm »
How did you guys wire these things?  My cabinet has a fluorescent fixture, but I don't know how to hook it up.
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=22758 if you can give me a hand I'd appreciate it.  Thanks.
roybfr
  • Last login:September 05, 2004, 01:50:44 pm
« Reply #5 on: August 14, 2004, 11:32:05 pm »
Is it better to get a light with a cover, or will an open light work fine.
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #6 on: August 15, 2004, 05:50:25 pm »
I used a light with a cover (which helps to diffuse the light a little better), but a standard open one would probably work okay.
Dougmeister
  • Dig-Doug
« Reply #7 on: August 15, 2004, 08:58:33 pm »
I just ordered a marquee from http://www.emdkay.net/ and am wondering if I should get a black light or a regular fluorescent.  Thoughts?
