Author Topic: Advice Needed:Keyboard Encoder for Very Simple CP  (Read 1432 times)
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
« on: August 11, 2004, 08:39:03 am »
So the first cab I'm going to build, to keep it simple on myself, prove to myself I can do it, and to prove to the wife that it's pretty cool, is a smaller Pac Cab.
Since I'm looking at basically a single 4-way joy, 1 & 2 player button, and a coin-up interface, am I better off just doing a keyboard hack, or should I spend the money on a minipac or ipac?
The intent would be to run ArcadeOS in a DOS interface and have the cab dedicated to Pacman itself, so I don't need a huge keyboard interface...
What would you do?
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
Re:Advice Needed:Keyboard Encoder for Very Simple CP
« Reply #1 on: August 11, 2004, 09:51:47 am »
personally, i would go with a keyboard hack since soldering is easy for me and you will only be using 2 or 3 simultaneous inputs at most.  plus the fact that i have an extra keyboard lying around helps..
gamepad hacks are a possibility also, but for DOS, you will most likely be looking for gameport ones with drivers, which may be more trouble than it's worth.
you "could" go ahead and get a dedicated encoder, but i think it would be overkill for a project like this and would try to avoid it unless you are deathly afraid of soldering and dont know anyone iwlling to do it for you..
SirPeale
  • Green Mountain Man
« Reply #2 on: August 11, 2004, 10:02:48 am »
Yeah, hack a KB.  Practice soldering first on scrap.
NinjaEpisode
« Reply #3 on: August 11, 2004, 10:03:15 am »
Welp, I'm all for the keyboard hack.  Worst case scenario, I fry a few keyboards working it out....
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: August 11, 2004, 10:11:38 am »
What would you do?
A keyboard hack would work fine for this (assuming you don't make really bad choices on inputs).
Considerations for an I-PAC/2 or KeyWiz (or KeyWiz ECO) (www.groovygamegear.com) - these might be a better option if:
- You may use emulators which don't allow re-mapping of key assignments -
- You don't like soldering (avoid the ECO, then)
- You will be building or improving your cab later and will need the I-PAC/KeyWiz then
- You want to save time and be sure the keyboard interface part of the project works.
