Author Topic: Video Amp, http://www.ultimarc.com/vidamp.html  (Read 2226 times)
SirPeale
  • Green Mountain Man
« on: August 10, 2004, 10:40:06 am »
Two questions.
1) Why isnt' the video amp listed on the main page? You have to go thru the ordering section to even know it was there.
2) It says that it has the exact video amp circuit as the J-PAC. Does that include where it splits the signal if it is more than 15KHz as well?
Lance
  • Last login:December 08, 2008, 10:20:09 am
  • banned
    • arcade.spamrevenge.com
Re:Video Amp, http://www.ultimarc.com/vidamp.html
« Reply #1 on: August 10, 2004, 10:54:14 am »
I have one and I am fairly certain it doesn't split the signal if it is > 15khz
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #2 on: August 10, 2004, 10:57:54 am »
no the amp does not split the signal.
only amplifies RGB and HV sync signals of VGA to 5v for arcade monitor.
do you want am ultimarc video amp?
i have a spare one (unused). let me know.
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
« Reply #3 on: August 10, 2004, 11:10:56 am »
I asked Andy a while ago and it won't split the signal. I have a hunch if those things worked like the j-pac they would sell like hotcakes.
Curls in the squat rack !?!?!
SirPeale
« Reply #4 on: August 10, 2004, 11:36:46 am »
Well...crap.  That won't do.  I've got a cabinet all ready to go, except for this part.
I'd use a JPAC, but it's serious overkill for this project.  Galaxian cabinet: left, right, fire, P1 start and P2 start.  Running VAntAGE.
rchadd
  • Made in Cornwall
« Reply #5 on: August 10, 2004, 11:44:47 am »
i'm interested to know why you using VAntAGE instead of early version of Mame (eg .36) is it better?
Edgedamage
« Reply #6 on: August 10, 2004, 11:48:44 am »
Or you could just hack a vga cable not all arcade monitors need the vid amp. And install arcadeOS and set it to acrade monitor. Could make a lean mean DOS system for that cab.
SirPeale
« Reply #7 on: August 10, 2004, 11:53:10 am »
Why VAntAGE?  It's running on a 486!  It works, so why not?  Besides, VAntAGE is kinda close to my heart and all...
There are not (many) problems once it actually gets *into* 15KHz mode, but I don't want to blow the monitor waiting for that moment.  Oh, and it does need an amp, I've already tried the VGA cable hack.
SirPeale
« Reply #8 on: August 14, 2004, 01:39:25 pm »
rchadd: I sent you a PM.
If I can't get the signal split, perhaps I'll rig up a timer to turn on the monitor after a minute or so.  Maybe I'll also see how badly the monitor screams.
