Author Topic: MAMEWAH & CREDITS??  (Read 2420 times)
scottyarc2
  • Last login:November 10, 2005, 05:33:53 pm
MAMEWAH & CREDITS??
« on: August 09, 2004, 04:44:51 pm »
Im running Mamewah as my FE
Is it possible (or does it exist) to press a combination of the arcade buttons to add credits, thus saving either seleting 5 on the keyboard or pressing the coin op switch (or inserting money!!!). Help please
simplygriff
  • Last login:January 10, 2008, 10:05:05 am
    • simplygriff.com
Re:MAMEWAH & CREDITS??
« Reply #1 on: August 09, 2004, 04:57:48 pm »
Mamewah has nothing to do with this setting.  You just need to set up one of your buttons in MAME to be your credits button.  You can do this by pressing tab in MAME, going into Input's (general), scroll down to the coin 1P and then press the button you want to use for the coin up.  it's probably a good idea to set it up to still use the keyboard key 5 as an optional way to coin up for testing purposes and maintenance.  To set an or command press the button you want to use as the coin, then wait about 5 seconds and press the other key you wan tto use for coin.  It should pop up as an "Button" or "5"  Depending on your set up you would also want to set up your coin 2P the same way. except use "6" and your 2P coin button.
Disclaimer:  This is just a basic explination.  If you're using Joytokey or some other encoding program it may be different for you.  You just may want to set it up according to your liking.
If this is confusing I'll try to explain better.
-G
www.simplygriff.com
art : videogames : transformers : life
Live, but Under Heavy Construction
lokki
  • Last login:May 05, 2025, 06:18:51 pm
« Reply #2 on: August 09, 2004, 05:19:10 pm »
What keyboard encoder are you using?
Most allow for a shift key configuration....
Ultimarc to add credit you do Player 1 start, player 1 fire
(player 1 start being the shift key)
scottyarc2
« Reply #3 on: August 12, 2004, 04:52:48 pm »
Cool, I am using a Ultimarc Jpac, so this solves the problem, well almost!!! I would like to add a two player coin option also 'coin 2' so i can have 2 play games such a gaunlet which must of had two coin mech in the machine, is that making sense!!! Basically how do i program the J-pac, I looked on Ultimarc and theres a utility program but im not sure how to use it??
« Reply #4 on: August 13, 2004, 12:26:37 pm »
Dunno about JPAC's, possibly with the same utility as the IPAC (?)  If you get no joy here try the Ultimarc board @ MameWorld...
lokki
« Reply #5 on: August 13, 2004, 12:43:48 pm »
The default key mappings for the Ipac are
http://www.ultimarc.com/jpac2.html
(there is no 2 player coin mapped by default)
Programming the jpac is pretty easy just run the application and should be pretty self explanitory.
