Author Topic: ArcadeVGA Vertical Roll  (Read 1491 times)
Halo
  • Last login:April 26, 2005, 03:00:03 am
  • I'm a lamer!
« on: August 08, 2004, 06:47:35 pm »
I have just connected a JPAC and ArcadeVGA to my cab. The cab works perfectly with Jamma boards / MVS / CPS systems. With The PC connected through the JPAC and ArcadeVGA, I get constant vertical roll. It can't be stabilised with the V-Hold pot, and the screen also has the jitters.
Any idea what this could be?
Thx
TJ
A stone falls on the pot, woe to the pot. A pot falls on the stone, woe to the pot. In both cases it is bad for the pot.
delta88
  • Last login:July 14, 2026, 12:34:36 am
  • This place is still here?
Re:ArcadeVGA Vertical Roll
« Reply #1 on: August 09, 2004, 01:46:44 am »
I believe you need to combine both the H and V neg- sync's going from the vid card onto the monitor. had the same issue
Halo
  • I'm a lamer!
« Reply #2 on: August 09, 2004, 03:06:52 am »
Thanks a lot :)
I'll give it a go!
TJ
