Author Topic: Emu Buttons and finding ESC for IPAC 2? And other questions!  (Read 2658 times)
Soulcon
  • Last login:November 15, 2004, 07:15:08 am
  • Goober
« on: August 06, 2004, 11:15:34 am »
I read a little about Mamewah being able to utilize multiple emulators. However switching from one emu to another is a bit vaque (to me). Will I need a seprate button per emulator or two buttons that will switch between them ? How would I go about switching emus normally? My goal is to have NES, Atari, and a few 2 button Mame games. Could someone inform me of how to switch between these three. Or atleast inform me how Mamewah goes about switching between different emulators? I have been so confused and I didn't want to Have 50 bajillion buttons all over my CP. Please help. Thanks!
-Soul
« Last Edit: August 08, 2004, 09:35:06 am by Soulcon »
For a free XBOX, PS2, or Gamecube click Below http://consoles.prizecube.com/?ref=6788
To get a free Personal Video Player go here! http://www.pvps4free.com/default.aspx?r=1848
Re:Mamewah question Emu buttons?
« Reply #1 on: August 06, 2004, 11:20:32 am »
You have 2 main choices on how to switch emulators:
1) Use Previous and/or Next Emulator buttons to cycle through.  Personally I only use a 'Next Emulator' button.
2) Use the Options Menu to select an emulator from the list.  This is handy if you really don't have any spare buttons :)
Soulcon
  • Goober
« Reply #2 on: August 06, 2004, 11:26:19 am »
Thank you so much for the sped fast reply You just saved me a million buttons :). On a minicade it can be pretty tight :). Thanks so much.
-Soul
« Reply #3 on: August 06, 2004, 11:32:13 am »
-Soul
Cool, please don't add any buttons on my (or MW's) account...you should be able to get by with 1 stick & 2 start buttons, any extra buttons are a bonus :)
Soulcon
  • Goober
« Reply #4 on: August 06, 2004, 11:45:01 am »
Great Thanks! Time to redrill a new CP :)
However how with only one start button how would you utilize the Select button for NES emu's?
-Soul
« Reply #5 on: August 07, 2004, 08:34:07 am »
-Soul
Ah with only 1 start button you will need one other button, presumably you have a fire button or 2 which could be used tho?
Soulcon
  • Goober
« Reply #6 on: August 07, 2004, 09:21:21 am »
Aye! I started configuring it all last night and I must say I LOVE this program. And with getting in it and changing things around I figured how I am going to set my buttons. Thank you so much for your help My daughters arcade is finally coming together :).
-Soul
Soulcon
  • Goober
« Reply #7 on: August 08, 2004, 12:06:23 am »
How can I make it so Button 3 is my exit key in Z26 and VirtuaNES?
Either that or how can I set Button 3 on the Ipac 2 to be ESC?
Only thing holding me back Mame is easy to configure that stuff to work but the other two are basically hard incoded to use esc.
-Soul
Soulcon
  • Goober
« Reply #8 on: August 08, 2004, 09:34:18 am »
~~~~~~~~~~~~~~~~~~~~~1~~~~~~~~~~~~~~~~~~~~~~~~~~~
Things I have tried!
1. Going into each emulator M.A.M.E, VirtuaNES, Z26 and tryed making the exit button corespond with my Button 3 on the Ipac.
Result: M.A.M.E worked like the trooper it is and said "go forth young man and assign as you so choose". VirtuaNES, Said "Nope I don't like you at all so shoo you nasty human". Z26 Didn't even say anything it just sat there like a lump on a log.
2. Tried using the IPAC Software but basically all I could figure out was how to make a pretty diagram of my control panel. Couldn't figure out how to force buttons to keys and such.
3. Searched for ways of doing this and came up with nothing PLEASE HELP  :( :(
Ideas: Do I need to change the wireing from button 3 to like something like button 6 on the Ipac?
~~~~~~~~~~~~~~~~~~~~~~~~2~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Also How do I have it so Mamewah is my startup program? If there is a site or faq to this I would be greatly appreciative.
~~~~~~~~~~~~~~~~~~~~~~~~~3~~~~~~~~~~~~~~~~~~~~~~~~~~~
How bad is it for an XP machine to be turned on and off via  a power strip? Will it eventually start loosing information? or blow circuitry?
Gosh I feel like a newb ;)
-Soul
Re:Emu Buttons and finding ESC for IPAC 2? And other questions!
« Reply #9 on: August 08, 2004, 11:00:14 am »
1) Use the IPAC's shift function, so you don't need an escape key.  By default P1 Start is shift, and P1 Start + P2 Start = Escape.
2) Easiest way is just put in your Startup folder...there are also ways of making it your Windows shell - search this board ('mamewah shell' or similar), there are a lot of topics about it.
3) Don't do that.  It won't blow circuitry but it will mess up your Windows swap file.  Use MAMEWAH to shut your machine down cleanly.
Soulcon
  • Goober
« Reply #10 on: August 08, 2004, 11:28:13 am »
Minwah to the rescue again Thanks bud I appreciate it. However I already have a button setup for exit on my panel. Would it work if I just run a positive wire to both Player 1 and player 2 and connect it to my Exit button?
And is it discussed in the mamewah Faq on how to turn off your system?
-Soul
Tiger-Heli
    • Tiger-Heli
« Reply #11 on: August 10, 2004, 12:45:07 pm »
-Soul
I got lost somewhere on what you want to do - Button 3 is supposed to be Escape right? (dedicated Exit button, not combined Button 3 for MAME and Escape for ZSNES, right?)
Just re-program your I-PAC so Button 3 generates Escape.  I don't have so software running, but see this page - http://www.ultimarc.com/winipac_ipd.html
You want to click "Go to Set KEYCODES Mode" and then in the table change P1SW3 to Esc and click Program.
