Author Topic: ArcadeVGA and WG9200 Setup Request  (Read 2265 times)
squizz
  • Last login:May 20, 2005, 05:32:41 am
« on: August 05, 2004, 06:11:31 am »
 Hello........
    I'm about to install my arcadevga card into the cabinet with a wg9200 monitor , and was wondering what is the best way to get each game running to the best as one can get it Looking......
  So is there a quick setup that you do from scratch?
 I'm running Mamewah as a frontend loader also !
Thank you.
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
Re:ArcadeVGA and WG9200 Setup Request
« Reply #1 on: August 06, 2004, 11:36:31 am »
I have the same hardware setup as you but I use MAME32, did you check out the Arcade VGA setup page on the Ultimarc site.
Gary
Effayy
  • Last login:August 18, 2006, 02:09:07 pm
  • Slowest....Cab Builder.... EVER.
« Reply #2 on: August 06, 2004, 01:36:29 pm »
Hello........
Thank you.
At http://mamewah.mameworld.net/downloads.html, download the "ArcadeVGA M.A.M.E Resolution Tool".
I haven't used it yet (have yet to build my cab), but I plan on the same setup as you, and came across the link when doing some research.
- FA
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« Reply #3 on: August 17, 2004, 02:09:34 am »
if your using dos i would reccomend advancemame and arcadeos. they work gereat together and you can fully configure your video to how you want it. if your using windows i would get the video tool that was mentioned previously.
squizz
« Reply #4 on: August 17, 2004, 07:58:57 am »
Thanks guys
   I'm using mame windows and tried the ArcadeVGA M.A.M.E Resolution Tool.
everything is great except i notice that i have to enable hardware stretch or otherwise the screen is only half the size...
owell
