Author Topic: MAMEWAH V9.54 - V9.70  (Read 1881 times)
spottydog
  • Last login:July 13, 2007, 07:58:40 am
« on: August 01, 2004, 07:04:12 pm »
Hello, I need one of these files for use with David Butlers Mamewah set-up program. Can anybody help?
EndTwist
  • Last login:May 26, 2022, 05:04:49 pm
  • Arg.
Re:MAMEWAH V9.54 - V9.70
« Reply #1 on: August 01, 2004, 07:19:24 pm »
What files?  ???
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
« Reply #2 on: August 01, 2004, 10:56:19 pm »
Do you mean .95 - .97 ???
There is no MameWah v9.x.
If you are in fact just looking for the regular download, try the homepage http://mamewah.mameworld.net/
PS - if you are looking for the normal files... may I suggest a search on the board or perhaps google in the future?? I mean.... come on now, we can't do everything for you  :P
first off your and idiot
spottydog
« Reply #3 on: August 02, 2004, 01:46:12 pm »
I'm searching for any version of mamewah between and including v9.54 to v9.70
David Butler's set-up program will only run with these versions.
I have already tried a google search without success, and visited the Mamewah site. 8)
pointdablame
« Reply #4 on: August 02, 2004, 03:11:26 pm »
There is NO version 9.anything.
At all.
NONE. :)
The newest version is .97  I just looked at the Mamewah setup site and I'm not sure why he wrote it that way, but he is incorrect.
Look here at the MameWah news page: http://mamewah.mameworld.net/news.html
Scroll down and you'll see that there has never been an releases in that numbering scheme. Probably just a typo on the MameWah Setup page.  Just download the newest version of MameWah and you'll be set.  And honestly, MameWah is pretty easy to set up anyway, you could probably do it yourself.
« Reply #5 on: August 02, 2004, 04:37:24 pm »
While I call my versions eg 0.97, technically using Micro$oft's major/minor/revision system, this would be 0.9.0.7 (hover over mamewah.exe to see).
I think David has interpreted this in his own way, perhaps I will ask him to change it to avoid any confusion...
Dave Butler
  • Last login:October 27, 2016, 03:31:16 pm
  • What does this button do?
    • MAMEWAH Setup
« Reply #6 on: August 02, 2004, 05:36:51 pm »
Sorry about that.  ;D
It's just the way that VB works out the version ie major/minor/revision.
Will change it..........
« Reply #7 on: August 03, 2004, 06:28:51 am »
Cool...
In future I will try to use more sensible version numbers!  :)
