September 22, 2026, 10:16:55 pm
1. When useing the configuration wizard, hitting back at certain points causes the program to error out.
4. You should be able to have multiple copies of each label
It would be nice to have the program run as a batch process to create control panel images. That way it would mesh well with the work I'm doing on displaying control panel images within MAME when pause is pressed.
