Author Topic: Possible solutions for disabling buttons on a CP  (Read 1083 times)
PixelCloud
  • Last login:April 26, 2005, 07:15:14 pm
« on: July 30, 2004, 10:49:21 pm »
So say you have a spinner with a couple buttons which are wired to the same buttons as say p1 first and 2nd button for the joystick
could you wire a switch that would switch between which ground wire is hooked up ?
so when you wanted to use  the spinner configuration the swtich would disconnect the ground wires for the player 1 joystick configuration..
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re:Possible solutions for disabling buttons on a CP
« Reply #1 on: July 30, 2004, 11:15:15 pm »
Yes, that should work.
