Author Topic: Front end for windows games ?  (Read 3056 times)
derek1800
  • Last login:January 29, 2005, 03:23:31 pm
« on: July 29, 2004, 03:32:27 pm »
I am in need of a way to play games that require a cd w/o having to put the cd so I dont have to reach into my driving cabinet to change to a different racing game.
FIXED by using no cd patches
**** Is there a front end that I can list all the windows games I have(1 lsit).*******
« Last Edit: July 30, 2004, 11:07:41 am by derek1800 »
Wizard of DelRay
Re:Is there a way to play games that require the cd w/o the cd
« Reply #1 on: July 29, 2004, 03:58:06 pm »
Not sure exactly what racing games you want to play, but you might want to check out www.megagames.com
mr.Curmudgeon
  • It's going to hurt your brain. A lot.
  • Last login:October 11, 2021, 07:15:49 pm
  • Huzzah!
« Reply #2 on: July 29, 2004, 04:03:06 pm »
You could create an .ISO image of the CD on the hard drive and then mount it as a "Virtual Drive" using a program like Alcohol 120%.
There are other virtual CD/DVD programs, but I already had Alcohol 120% since it's also a great piece of burning software. Try Google for more info.
« Last Edit: July 29, 2004, 04:03:45 pm by mr.Curmudgeon »
derek1800
« Reply #3 on: July 29, 2004, 04:24:19 pm »
I went to gamecopyworld hopefully the patches will work :)
Derek
photorock
  • Last login:March 07, 2006, 08:37:03 am
  • Goofy Newfy!
« Reply #4 on: July 29, 2004, 10:12:26 pm »
        Copy the contents of the CD to a folder on your HD and install from there. When your computer asks for the CD change the path to the folder on the HD. Should work depending on OS used.
derek1800
Re:Front end for windows games ?
« Reply #5 on: July 30, 2004, 11:08:13 am »
 Is there a front end that I can list all the windows games I have(1 list).
PiNPOiNT
  • Last login:November 19, 2010, 05:00:59 pm
« Reply #6 on: July 30, 2004, 11:53:07 am »
There's a front end that you can buy call applauncher that should work for what you want to do.  try out the demo first.
sorry i dont have the link
its a dumb little program for 20 bux,
not the super expensive $250 program that you might come across when you google it
« Reply #7 on: July 30, 2004, 12:14:56 pm »
MAMEWAH can do it...
derek1800
« Reply #8 on: July 30, 2004, 12:49:30 pm »
found on faq
Derek
« Last Edit: July 30, 2004, 12:52:02 pm by derek1800 »
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Mr. Dude
  • Last login:March 03, 2019, 05:12:50 am
  • Hi...
« Reply #10 on: July 30, 2004, 03:34:00 pm »
Applauncher for $20 is a total ripoff.  I use MameWah and you can make a PC Games list with it.
