Author Topic: i hate latex paint ; ;  (Read 1769 times)
krion
  • Last login:January 13, 2021, 01:18:20 pm
« on: July 28, 2004, 10:13:21 pm »
Spent the last couple of days putting latex on my cab that I recently took side art off of...  I went down tonight to prep the cab for final coat of paint and when I was sanding it the stuff just started to peel off more or less...
Im pretty sure that there was no "goo" left after removing the side art and I sanded it pretty well after as well...  The paint appeared to be clumping on the sander...  Not coming off as "dust" but gathering into sticky clumps.  Im not sure if this is an affect of painting particle board with latex or what.  I mean, i let each coat dry for at least 8 hours.
Anyhow... if there are any experienced painters out there.... How do I fix this?  Do I have to strip all of the paint down back to the wood with stripper and use an oil based on it?
TYIA for info, this has me quite frustrated at the moment.
old school gamer
  • Last login:December 22, 2006, 02:20:28 pm
  • Woodworking Genius, computer illiterate!
    • my homepage
Re:i hate latex paint ; ;
« Reply #1 on: July 28, 2004, 10:28:10 pm »
Latex paint will tend to "clump" up when sanded if not completely dry. I would suggest letting it dry for a day or so and sand it down and try again. Oil based paints are the best for nice finishes,but can be trickey to use.
My tag line was inappropriate for a family oriented site. It has been changed by saint.<-- THATS better than anything I could have come up with!!!!!!! Thanks Saint!!!-
Zakk
  • Last login:Today at 04:23:31 pm
« Reply #2 on: July 28, 2004, 11:45:26 pm »
Just a guess, but one, that paint sounds like it hasn't cured at all, and two, you could really do with a coat of primer first.  Primer 'primes' the surface and gives the final coat of paint something to stick to.
 Out of curiosity what was the sideart beforehand?
MonitorGuru
« Reply #3 on: July 29, 2004, 11:55:00 am »
NEVER apply Latex paint directly to particle board!
If you must use latex paint, prime the board with a good oil-based primer (to stick to all that exposed glue in particle board) such as KILZ original ($8 a gallon at home depot--a steal).
Remember latex over oil is okay, oil over latex is not.
Give it a good couple sandings to remove all bumps, and perhaps put two coats of oil primer.  This will make your life MUCH easier and give you a nicer cab.
Safron
  • Last login:September 27, 2004, 12:00:41 am
« Reply #4 on: July 29, 2004, 02:01:14 pm »
Always apply liquid latex to your woman.
You will learn to love latex after that  ;D
krion
« Reply #5 on: July 29, 2004, 09:44:29 pm »
i stripped the latex off down to the wood again, sanded it with very course sanding block and applied a different ( special ) latex primer.  I did it this morning and it seems to have dried and adheared to the wood very well.  Although, after my last experience, im going to let it dry over night to be on the safe side before I see exactly how well it did.
