Author Topic: Specifying multiple ROM paths in MameWAH?  (Read 1631 times)
SirPeale
  • Green Mountain Man
« on: July 28, 2004, 03:33:07 pm »
How do you do it?  I've tried different seperators between the paths , ; | and it doesn't like any of them.
Or am I just doomed to one path?
Wizard of DelRay
Re:Specifying multiple ROM paths in MameWAH?
« Reply #1 on: July 28, 2004, 04:30:37 pm »
I tried to do the same thing (since I keep my Sega CD isos in seperate folders) but it didn't work.  I assume it can't be done because in Mamewah Set-up it only lets you choose one path, but I hope I'm wrong.
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« Reply #2 on: July 28, 2004, 07:54:47 pm »
You are right, it can't be done in the current version.  You can do it for MAME by specifying the multiple paths in your mame.ini file though.
P.S. this has been posted quite a few times in the last few weeks.
« Reply #3 on: July 29, 2004, 06:52:45 am »
For MAME, as long as you specify your paths in mame.ini (as stuzza says), and use the 'Verifysets' List Gen. Method, then multiple paths will work.
For other emulators, you're stuck with 1 path for the moment :(
SirPeale
« Reply #4 on: July 29, 2004, 09:01:53 am »
I am using Mame.  The paths are specified (and tested working) in mame.ini.  The 'VerifySets' has been selected.  Go to 'Refresh Games List' and nothing happens.  Heck, it doesn't even generate an 'EMU1.LST' file when I do that.
I'm obviously missing something, I'm just not sure what.
Edit: is this for versions BEFORE the xml?  I'm using .84u5 and it does not seem to want to run the -listxml command.
« Last Edit: July 29, 2004, 09:13:17 am by Peale »
« Reply #5 on: July 29, 2004, 10:53:20 am »
Sorry Peale, I forgot about v0.84...
I have added a new 'Verifysets vs Listxml' List Gen. Method which will work for what you want...but you'll have to wait for my next version  :-\
The workaround for v0.84 is usually making a dat file - if you have a complete set then you could use the 'DAT File Only' method, otherwise 'ROM Folder vs DAT File' will only be able to handle one of your rom paths  :(
SirPeale
« Reply #6 on: July 29, 2004, 12:37:51 pm »
Bah!  Only ONE ROM path?
I've changed my mind;  I'm adding you to the list.
« Reply #7 on: July 30, 2004, 05:04:05 am »
Yeah I know...I need to add multiple rom paths, but I'm waiting until I re-write a bunch of stuff as it will fit in nicely...
I'm sure I'm being thick but what list ?  ::)
SirPeale
« Reply #8 on: July 30, 2004, 10:30:30 pm »
I'm just giving you crap.
Slacker.
